Definitely run the fuel rail back to the surge tank and then an overflow back to the main tank. If you don't do this your asking for serious potential issues:
Lift pump is bigger than main pump: your lift pump will be pumping into a tank that is already full and the pressure build up will be massive as there will be no way to regulate this (like 100psi!!) - this will kill the lift pump eventually and maybe even spilt your lines/tank and cause a massive fuel leak.
Main pump is bigger than your lift pump: your surge tank will eventually drain itself dry and you will have massive fuel starvation problems.
Bottom line - set it up with a rail return / overflow and save yourself the potential massive issues.
