Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: Aftermarket Digital Odometer
    Default Re: Aftermarket Digital Odometer
    Quote Originally Posted by bathurst-91
    I say ODO reading should be taken into a rta logbook when you go get slips. So when you go to buy a car you can see its 100% accurate.
    You'll find it probably is.
    I know in WA when you buy a car you have to put ODO reading on the rego papers.
    But remember, you can always swap dashes.
    I'm not planning to wind it back. The first thing I'm going to do once I get it all working is to set the odometer to what it currently reads. I'm not looking for anything dodgy, just something that's going to work with the digital sender.
    Of course, if I do happen to grab a factory dash with an odometer, I need to make sure it accepts the same pulse count per km as the factory speedo...
    User Conversion King
    NWA
    the recent model echos have a digital odometer....might want to take a look at them.
    although....they have a big magnifying glass infront of the LCD so im unsure of the actuall size.
    hello
    whats the go though when someone has done an engine swap? Do the KM's accrued with original engine remain the same, or does it get adjusted according to the logs from the new engine?
    How about a programmable panel meter like this?
    It even has inbuilt scaling so you can program it to count x number of pulses as one count increment... it also has programmable alarm outputs so you could program in things like timing belt replacement schedule or service schedule etc.
    Junior Member Backyard Mechanic ndgcpr's Avatar
    Quote Originally Posted by MFN-MAN
    usually people leave it at the old motor reading and record number of klms to conver it, but i dunno, i was lucky enough (since my dash OD had broken) to fix it and have it roughly at the same place the motor i pulled out was at. i think it is only a couple of thou out, so i have left it at that. People really don't care if its 96'000 as aspose to 99'000 whereas 150'000 to 100'000 would be bad.
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    Quote Originally Posted by Toobs
    That looks like my bitch! You are the bomb. Exactly what i'm after. When the time comes, I think thts what i'll be getting.
  1. JZX81 digital dash into MX83
    By Cressida91GLX in forum Tech and Conversions
    Last Post: 10-06-2009, 07:47 PM
  2. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 10:09 AM
  3. GZE Aftermarket comp issues
    By craigy in forum Tech and Conversions
    Last Post: 17-01-2006, 10:45 PM
  4. Speedo and Odometer questions
    By Big T in forum Tech and Conversions
    Last Post: 04-12-2005, 06:43 PM
