Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: GZE Aftermarket comp issues
    Junior Member Grease Monkey craigy's Avatar
    Default GZE Aftermarket comp issues
    Hey Guys,
    I'm in the process of wiring up an aftermarket computer to run a late model AE92 4AGZE, to be installed into an AE86.
    I've got a large part of the wiring sorted but i'm having a issues with the ignition setup, and was wondering what sought of arrangements other people have used.
    I'm using a v4 Wolf 3D and in the manual it has no diagram for a dual coil, single ignitor arrangement.
    I'm chasing up some wiring details for the standard ignitor/coil pack setup. Including what each wire does what (signal, ground, +5v etc)
    Also wiring info on the Cam angle sensor, including details of what wire does what. I have a diagram which has the CAS on it, but it does not specify what each of the wires does.
    Also I'm assuming that the CAS on the GZE in a hall effect type? which requires a voltage.
    Any help/experiences/diagrams would be fantastic.
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    Default Re: GZE Aftermarket comp issues
    Toyota CAS for waste-spark are reluctors not hall effect.
    Good starting point for reading on the Toyota DLI system is http://www.autoshop101.com/forms/h23.pdf (434Kb)
    start at page 9 for DLI specific stuff but the preceeding pages give you grounding in the technology. It does look at the 7mgte, but it and the 4agze work in similar manner.
    Cheers chuckster,
    Rep to you!
    Open for more advice/info from everyone
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    how will it work with only one ignitor?
    i had an idea to ghetto convert mine to multi-coil, was going to use 4 transistors and the standard ignitor (to allow me to use standard management)
    have you called wolf yet? a guy i went to uni with knows one of the partners of the company, and drives an AW11 with a silvertop 20 valve in it, so they will have heard of 4AGEs before.
    and IRA11Y had twin coils on his 4AG, using the CAS and two bosch ignitors..
    if it has a single ignitor now.. it MUST be a two in one to drive two coils..
    call wolf
    The original setup uses a single ignitor.
    So I cant really see any reason that the computer cant use the same arrangement.
    I havent spoke to wolf yet, I want to do a bit of research and get to know what I'm talking about before I call them.
    I've read in previous forums of people using the original coil packs with 2 ignitors from a different type of engine. I think it was a Camira.
    4AGZE powered AE86
    SR5 dual cab Hilux
    south australia
    hey mate,
    i went on the wolf web site and downloaded this guide. it might have some useful info for you.
    should point you in the right direction anyways. check it out!
    http://www.wolfems.com.au/products/e...nstallshortcut
    thanks for the effort, but I already have the Installation manual
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    u can get a bosch module which can have 1 or 2 or 3 outputs
    so depending which way u go
    i dont know why people dony run microtechs
    they have the best diagrams and have have good helpdesk after 2 pm
    if i get time ill try chase up part numbers of the 2 output ignitor
    think the part number ends with 002
    it has 2 inputsd and 2 outputs on one ignitor
    u can also look inside the cas at the wiring
    think white wire is common to all 3 sensors so this is the earth
    then u have green yell and i think red
    these 3 are the signals they are magnetic signals
    u only need to use 2 of them
    one of them is 4 pulses every 360 degrees the other is 24 pulses every 360 degrees
    but does yr wolf have 2 outputs
    someitmes there is 2 outputs but the manufacturer only fits a wire to ignition output 1
    unless u do these regularly they are the biggest pain in the assssss
    i can do a microtech with my eyes shut
    Junior Member Carport Converter 4agte's Avatar
    mine is using the 4agze distributer with all but 4 or is it 5 of the teeth ground off and the stock gze coil/ignighter.
    The teeth were ground off as the ecu wasnt getting a good signal and it was firing all over the place but aparantly you can fix this problem by buying a little black box from wolf that boosts the signal.
    If i could get power to my ecu i could have got the map for you as i belive that wolf didnt even have a map for the 4agze but they sent my tuner a map from a 3sgte which they altered the values for the smaller engine
    if u fit an autronic to a 4agze u have to cut all the 24 teeth but one
    u use this as a sync signal
    the u use the 4 teeth as a reference signal
    because not many people use these its hard to get the correct info
    and this is also one reason why it costs so much to get it installed and tuned if they have problems
    All you have to do is use a pulse or wave form analyser. Such as a CRO. If you spin the dizzy at a constant speed then you can take a reading of the signals coming down the lines.
    For reference, im using the stock 4AGE CAS (within the dizzy) and syncing off the 1 tooth Home, and then triggering off the 24 tooth sensor.
    don't want to take craig's thread too far off topic, but:
    sideshow, how well do microtech's handle Alpha-n configuration? (thats using throttle position and RPM as the primary load sensing for all those noobs like me) out there
    we should have a thread to answer common misconceptions about ECUs, i might even go start one.
    well microtechs can be tuned either map sensor or tps
    so i guess its all good just depends how good the tuner is
    just remember map sensor is bit better way to tune it
    the main prob is when people order a microtech they dont explain things properly
    basically u tell them these details
    engine type
    dizzy type
    how many coils
    etc
    and they will built an ecu to suit
    so basically if u have a bitsa engine then u can still get an ecu that will wire up easily
    and usually start first go
    a wolf is like an autronic
    it takes afew hours in setup time
    and unless u have expo3erience and good mutlimeters or oscilloscopes to test signals
    it make it difficult to find tiny problems
    so to the peron with wolf probs
    maybe try ringing any wolf experts in yr state
    ask them what the dizzy needs
    if it needs modifying then just pay them abit to modify it and ask them if it needs
    a signal booster or reluctor interface
    every thing else should be easy
    basically all u need on the ecu is power earth injectors and dizzy to get enigne to start
    theyre all easy but for the dizzy
    reason i ask is that with big cams you can't use MAP as a load input due to low vacuum, air reversion etc, anyway,
    /thread hijack off
  1. Curious Alternator issues (charging)
    Last Post: 12-01-2006, 08:41 AM
  2. 100kw in AE82 Idle Issues
    Last Post: 11-01-2006, 06:15 PM
  3. ta22 window issues?
    By weapon x in forum Tech and Conversions
    Last Post: 05-01-2006, 09:53 AM
