Results 16 to 30 of 37
Thread: Aftermarket Digital Odometer
    Default Re: Aftermarket Digital Odometer
    so when ya going to do it? it has to be able to count as high as a normal odometer obviously, and i'd like a trip meter too
    Junior Member Backyard Mechanic ndgcpr's Avatar
    PAITENT PENDING
    Say using a 16X2 LCD screen. top line in each corner are trip meters and bottom line can be odometer, you'll have 16 Chars, and using a 16bit number it will be able to count to 1'677'721.5
    so it will look like this
    AAAA.AXXXXBBBB.B
    DISTX1'000'000.0
    Where
    A = first trip
    B = second Trip (unless you want to hide one)
    X = space
    Two buttons, one to select the trip and the other to reset it, and special button hits to select the number for the odometer to start off at and number of pulses per K or something. Should start building them and sell them off lol
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    ?? There are digital sensors that connect the original cable to the box. Speed sensor on the tranny.
    Tim
    Ok..suggestions
    1) You could use an old gutted dash's cable -> square wave converter (*cough* I may have one) input that to a small micro controller and then display to a screen of your choice with a correction factor (change the 627 revs / km to what you require).
    OR...
    2) Take apart your dash and divert the square wave Speedo signal to a micro which then outputs the correct signal to the dash display...and then you can also have the micro controller display the correct odometer reading to the screen...but hey why stop there, why not have the micro log temps (water, oil, inlet, pre IC, post IC), boost, rpm and other! And take it one step further why not have it display it to your laptop in real time (bah ur getting microtech soon anyway so why bother )
    However I suspect seeing as your saying odometer you're after accurate fuel economy.
    How about this for a suggestion, get a digital speedo sender (at the box end, hey I know someone that has one of them too...not me this time ) and then use the microcontroller to drive a stepper motor at the correct speed into the dash?
    Some cool options
    Western Aus
    My supra has a digital dash, although i often wonder why the odometer is analouge :/
    everything else on it is digital though, including trip monitors (a and b) etc.
    pity you couldnt just hack up some other toyota dash
    Eldar.O.
    Wilbo, you hit the nail on the head. I'm after accurate fuel economy and an accurate idea of the kilometres I travel, so I can work out my oil changes. As cool as the stepper motor idea sounds, jimmying up a digital odometer sounds easier, or even a mechanical one that has an electronic input.
    Junior Member Domestic Engineer NeoNasty's Avatar
    thought about a push bike computer?
    I used to have one that had Kph and 2 trip meters and odo. Freakin kicked ass and I think it was only like 50 bucks. It even help your top speed.
    You just input the diameer of your tyre and install a magnet and sensor (drive shaft installation?) and BAM!
    Too easy. but it might not be quite the look you were after. You could hide it away in the glove box?
    EDIT: I think it could read up to like 180Kph too!
    HZJ75, RS41, JZZ30
    Quote Originally Posted by JustCallMeFrank
    Aww come on, make it happen! You know you want to
    I suggest starting at step one, and that would be to tap into the existing speed signal (which I believe does come out the back of the dash, ergo easy), connect it to a micro and let it display it to a small LCD...then when you want to step it up a notch you can hit it with your spice weasel and get the same micro to drive a motor to make the mechanical part accurate as well (and then ditch the LCD )....it's not that hard is it? Got beer and a bit of leeway in terms of a timeframe? I could look into doing it for you if you have both
    Haha, there is always beer.
    It all came about because my speedo is out, and it's because of the drive gear in the box, so it's not going to be changed. That requires removal of diff, tailshaft and gearbox, 3 things i'm not keen to do in a hurry.
    I'm planning to either use a UZS131 (or similar) electrical speedo sender, or the factory one in the back of the dash (which would still require a cable to replace my farked one), with the signal corrected by a Jaycar signal corrector.
    Of course this leaves me with a) no odometer/tripmeter or b) one that is still ~10% out.
    Hence my desire for a digital odometer to ensure I still have an odometer
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    i know dick smiths have a digital tacho that you put together yourself they might have somthing else like that.. a little tacky but fun.
    Sam.
    Yep, sounds like a good way to go about it. teh witzl might be able to suggest something (jaycar have a digi speedo but no logging as you prbly found)?
    But me, I love an excuse to put a microcontroller anywhere I can
    If you can come up with a microcontroller to handle a small LCD screen I could replace the factory odometer, with a button to switch between the odometer and the trip meter, then i'll take one
    Edit: (read your post again )
    If YOU can find an lcd to fit in that position with a datasheet or somewhere to get the info on how to drive said LCD I can't see it being hard (steal one from a new car dash?)
    Tis a good plan
    get a defi digital headd up display. has digital everything on it and it gets projected onto ya windscreen
    Junior Member Backyard Mechanic bathurst-91's Avatar
    Winding back of ODO's is a bastard thing to do. Mass market Digital ODO's would turn it to la-la land. I say ODO reading should be taken into a rta logbook when you go get slips. So when you go to buy a car you can see its 100% accurate.
    Just my 2cents
    -Andrew
    A race continues forever...
  1. JZX81 digital dash into MX83
    By Cressida91GLX in forum Tech and Conversions
    Last Post: 10-06-2009, 06:47 PM
  2. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 09:09 AM
  3. GZE Aftermarket comp issues
    By craigy in forum Tech and Conversions
    Last Post: 17-01-2006, 09:45 PM
  4. Speedo and Odometer questions
    By Big T in forum Tech and Conversions
    Last Post: 04-12-2005, 05:43 PM
