Results 16 to 30 of 33
Thread: DESPERATE car won't start
    Western Aus
    Default Re: DESPERATE car won't start
    Quote Originally Posted by BradW
    When did they bring in this law, it's news to me. Maybe just a WA thing?
    If you have fuel pressure and spark then there is only a few other things to check.
    Check to see if the injectors are firing and also check to see the spark plugs aren't fouled.
    Has it been serviced regularly/ lately?
    Remember, an engine needs three things to fire, Fuel, compression and ignition. If you have these three, then the engine should start.
    Good luck with it.
    i thought it was oar-stray-ya wide, apparently not!
    sounds like a dicky alarm system.
    mind you, ive had some funny shit go on on a few motors over the last couple of years, the weirdest being, pull lead off, plug spare spark plug in the end, ground spark plug (repeatedly!) no spark. put lead back on spark plug in head, engine starts...
    and people think cars and mechanicals are easy to understand.
    Elmo.
    Junior Member Backyard Mechanic sw20r's Avatar
    tried doing a clutch start or hitting the starter motor a few times? check the grounding to the starter motor, battery voltage. main fuses, ecu fuses too
    Canada
    Quote Originally Posted by sw20r
    In the first post he said it cranks fine.
    That would seem to suggest that your suggestions are unnecessary...
    Junior Member Chief Engine Builder wiso's Avatar
    well this one still has me stumped, which is odd
    Updates:
    the car still cranks fine, the battery went flat so we got a brand new one just incase.
    the alarm has been pulled out and all the wiring repaired.
    There is spark so there is nothing wrong with the ignition side.
    The fuel pumps works, but it looks like for some reason the injectors aren't putting the fuel into the engine.
    I pulled the plugs out after cranks a bit the plugs are dry. they should be soaked considering how much cranked.
    I tried some aerostart, she cranks and fires, runs until the shit is gone then stalls again
    So my vedict is for some reason the injectors aren't pulsing, or it has somehting to do with the Air sensor.
    I can't figured it out so i am gonna call an auto elec tomorrow see if he can come look at it. but if anyone else here may have any more sugestions??
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    Dubai
    at least you still have compression then.
    Does it have fuel? might sound stupid but i've seen it happen before.
    West Australia
    Quote Originally Posted by wiso
    Fuel not getting to cyl...
    If it works with "start ya bastard" spray shit ... but once u stop spraying it , it will stall , means that its running on that ... and not fuel. therefore , fuel is not going to cyl
    ur verdict about injectors sounds correct.
    My Missus is a Domestic Engineer BradW's Avatar
    Check for power at the injectors and do a continuity check on the wires between the injector and ecu.
    I have a diagram for a 96 1.8l (4g93 engine) and it shows the injectors getting their power supply from the engine control relay via fusible link F7. The coils on the other hand are powered directly from ignition switch terminal IG1, as is the fuel pump relay.
    Check the engine control relay to see if you are getting power through it if you have no power at the injectors.
    Hope this helps.
    Brad
    Old Corollas never die...
    My KE30
    yeah man, i know that. that just proved that the car will run, so its a fuel issue.
    yes the tank is almost full
    Hope this helps.
    I bought a manual for the car today. I have done checks on the injector lines, they seem fine, they aren't grounding to the car, and they have continuity between the ecu.
    fusable link f7? what is that. that would be smart, i didn't check the engine control relay yet. darr. I'll do that in the morning, heres hoping its buggared
    edit, i checked the manual, i think i know which FL that is
    89' MR2 AW11... His
    Are you getting an igniton supply to the injectors?
    Brad
    My KE30
    Xistant
    Guest
    Quote Originally Posted by celica_john
    yeaha about that, um hi! lol
    ha, i am not sure, i forgot to check that
    I guess the relay outline red/yellow is the power line to all the running systems. each injector, air sensor, and ISC motor.
    I'll be checking that first thing in the morning.
    if there is a problem hopefully it will be in that wire since that covers 2 of my suspisions
    89' MR2 AW11... His
    Junior Member Grease Monkey Adrian's Avatar
    Apr 2007
    W.A
    Check the Continuity within the injector as well it could be an open circuit inside the injector itself.
    well this one has been solved, I got an auto elec out to tell me everything I already new and checked for, there was no injector pulse.
    I found the cause for it, stupid thing actually, the roommate got a new key cut, but she didn't get the coded key, so the sensor on the ignition was locking up the standard immobiliser.
    Bullshit, all this and that was all it was, think about this next time with modern cars people
    89' MR2 AW11... His
    Good to know you solved it wiso.
    However, your original scenario didn't cover this situation - so.. be much harsher on whoever is telling you what they did - they obviously didn't tell you the whole story.
    Was she driving on the new key for a while before it stopped? or she swapped keys without realising it? or she has completely no idea what she was doing?
    It's funny how sometimes you can't even trust what the cream of the (intelligence) crop are telling you when you're trying to solve their problem... ask enough questions and the inconsistencies come out...
    Mos.
    Good to see you got it sorted.
    It is amazing how much easier it is to fix something when you get the story straight from the start.
    I was trying to fix the brake lights on an old crappy volvo tipper once and I asked the owner if he had done anything to it or changed anything. "No I haven't done anything" was the reply. After an hour or so of trying to work out what the hell was going on (nothing in the fuse/ relay panel was labeled) I found out that the relay was missing. When I told him what the problem was he says "ah yeah, I pulled that out" .
    Brad
    My KE30
  1. 4age wont start, distributor?
    By carsanactra in forum Tech and Conversions
    Last Post: 25-01-2007, 05:29 PM
  2. 4agze hard to start and then stalls
    By wiso in forum Tech and Conversions
    Last Post: 07-12-2006, 11:31 PM
  3. DIY alram install (auto start), for n00bs
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 29-06-2006, 03:19 PM
  4. 3SGTE Hard to start
    Last Post: 27-01-2006, 11:16 AM
