Results 1 to 10 of 10
Thread: aftermarket speedo in ae86
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    Default aftermarket speedo in ae86
    hello, just wondering what would be the procedure of fitting like a splitfire speedo in a ae86. i know it;s a mechanical cable, but is there anyway to make an elec gauge work? even if i get a mech gauge, how can i calibrate it? reason for asking is i want to make a custom dash.
    thanks
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    apprentice pwnerer Grease Monkey phrostbyte's Avatar
    Default Re: aftermarket speedo in ae86
    I believe you can get a kit from Jaycar that reads the mechanical cable and sends out an electronic signal.
    Kev.
    RIP Kev. You'll be missed.
    Old worklog of the last 2 KE70s (long since updated): http://ke70.theicy.net/
    Current AE71 4AGE Daily Driver (Soon to undergo AE86 front end and rear bumper!!: [COLOR=Blue][url]http://www.toymods.net
    beautiful. just found out how expensive these gauges are!!!
    all good though.
    once u get that kit, do you stiff have to calibrate the gauge?
    thanks
    After a quick search of the Jaycar site it seems there's none there. But I remember a thread on the old toymods saying something about a mechanical to digital converter, give that a shot.
    And no, you'll probably have to adjust the converter, but the speedo itself will tell you exactly what the converter is telling it. I believe it would probably be pretty easy to set the converter. I'm pretty sure its ~637RPM of the speedo cable = 1kmph.
    Kev.
    beautiful, exactly what i needed.
    thanks rep+
    The UZS131 Crown has an electronic speedo sender which just clips onto the speedo gear. Jaycar don't sell one of these, but they do sell a corrector for them, costs about $45.
    Apparently sideshow usually has one to two at least of the senders kicking around at any one time.
    Hope that helps.
    Where did you get the Splitfire gauge from?
    Is it in km/h?
    Is it a 6" gauge?
    Do you have a close up pic of it, please!
    Phil
    Celica28
    Jun 2009
    VDO have a convertor also,bolts on top of the std speedo drive. can have multiple outputs as well.
    their speedos are programmable for rolling diameter,gear rartios and so on also AFAIK.
    Justin...
    Just go get an electronic speedo sender from any wreckers. AE101, AE111, MX83, most Camrys and others will do just fine.
    The speedo will have a corrector in it if its a decent one.
    For stock T50, you can bolt-on;
    * Nissan (pulsars) (4 pulse per rev - from memory)
    * Crown/Cressida (Some have, some don't - generally the digital dash ones do) come in 20 ppr and another i can't remember.
    Choose the sensor that would get closest to what the spitfire accepts. The more ppr, the more accurate the readings. If the pulses are way off, you may need a speedo multiple. Note that the jaycar one is limited to +/-100%. If you need more they can get pricey unless like electronic stuff.
  1. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 10:34 AM
  2. Further adding to Article - Putting S13 susp. into AE86.
    By Sprinter-Saurus in forum Tech and Conversions
    Last Post: 27-01-2006, 09:42 PM
  3. GZE Aftermarket comp issues
    By craigy in forum Tech and Conversions
    Last Post: 17-01-2006, 09:45 PM
  4. Speedo and Odometer questions
    By Big T in forum Tech and Conversions
    Last Post: 04-12-2005, 05:43 PM
