Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 96
Thread: ke30 3rzfe turbo
  1. #46
    Junior Member Backyard Mechanic rodi's Avatar
    Apr 2007
    Default Re: ke30 3rzfe turbo
    Quote Originally Posted by BeRad
    nice work rodi, good to see the 3rz in something that weighs nothing cant wait to see it in action, hows mod plating go with a 2.7 turbo in such a light car?
    2rzfe looks exactly the same???????
  2. #47
    Apr 2007
    1 lavender close
    that awesome
  3. #48
    haha true i spose
  4. #49
    May 2007
    Miami, FL, USA
    I dont have a 3rz, I have a 2rz (which is nearly identical -.3 L on displacment), but with a nearly sotck long block(only upgrades are headstuds and a metal headgasket), I am pushing 380hp/380tq to the wheels at 22lbs. You have to be careful with the timing, as this motor is prone to detonation, but if you clear that up, there is power to be made in stock form. My ultimate goal before a rebuild is 500hp on the stock motor.
  5. #50
    Apr 2007
    Hi Atomic Speedware do a set of arias pistons & rings. 8.5cr for under $500 US under $650 landed, head gasket $80 US Help me with specs of your motor ,im on a steep learning curve. What head mods, fuel pumps, injectors, max advance at 22psi, cr, exhaust pipe size etc etc. 380rw sounds good, whats it in. Rod
  6. #51
    ochizon, im curious to have a look at your ignition map if you dont mind, and peak ignition advance, as im thinking ignition is what killed mine...
    also does the 2rz have balance rods? youd think so being the same motor as the 3rz really, do you think youll run into problems with the balance rods at 500rwhp? i guess its unchartered territory.. with good tuning i guess anything is possible..
  7. #52
    Apr 2007
    can,t see how the balance shaft would know what hp the crank is putting out, maybe they have probs above std revs, anyone know?
  8. #53
    Rosewood
    well im making close on 400rwhp with my 3rz, and its still stock bottom end as far as i know. balance shafts and all...
    people generally disable them because they chew up HP because of rotational weight.
  9. #54
    Rosewood
    im looking at removing the decompression plate, and replcing it with a 2 or 3mm thick custom multilayer steel from Cometic. with ARP head studs to keep the head on.
    Im only pushing 20psi, with no knock, and a mother load of advance, with 550's at 100% I reckon there is still more in it.
    Depends if the car sells or not will depend if i go further. its just silly on the street. Would like to change it to an auto... i dunno can't make my mind up.
  10. #55
    Rosewood
    www.paradiseracing.com
    These guys love the 2rz/3rz, they have 3mm cometic headgaskets for $149USD. ARP Headstuds for $140USD, and adjustable cam gears...
    I'm almost tempted to keep the ute now.....
  11. #56
    buzz engines who built the 00lux00, told me that the balance rods let go on the 00lux on a stock engine pushing 450hp destroying the block, when it was pulled down the pistons were fine and the rods were bent from the rods letting go.... so they say.....
  12. #57
    Nurses rock! Grease Monkey lunar_c's Avatar
    Feb 2007
    Sweet conversion mate.. be sure to post when you have the next update.
  13. #58
    back at redlands i always had to straighten the balance shafts, they would get a bend in them just behind the fron bearing surface, which would shit hte bearing and/or put a huge wobble in the gear causing a chain failure
    The boobs are back
  14. #59
    ding dong maybe my problem was what mr dohc mentioned. and when the chain fails? the engine becomes out of control balance wise.. which isnt much chop when the engine is under alot of load.
    since youve worked with them before? to disable them what needs to be balanced so it doesnt explode.
  15. #60
    coulda pumped swarf into the oil galleries causing bearing failure in the rods, hence, boom = rods
    The boobs are back
    Last Post: 03-05-2009, 06:47 PM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 12:43 PM
  3. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  4. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
