Page 6 of 7 FirstFirst ... 4567 LastLast
Results 76 to 90 of 96
Thread: ke30 3rzfe turbo
  1. #76
    Default Re: ke30 3rzfe turbo
    paradiseracing.com in the states sell alot of goodies for the 3rz also afterall they own the 1300hp 3rz ... adj cam gear, cams , forged internals etc etc all pretty cheap also...
    im not sure if they still do but a.r.e at brendale in brisbane had 3rz forged internals for sale leftover from there build when they chose to import a built block. might be worth a call.
    pauter rods are 735us...
    http://www.paradiseracing.com/rods.htm
    http://www.toyotacatalog.net/M1WebGe...px?Class=14630
    lc engineerings rods are 800us
    a bit of research for you because im bored
    instead of clogging up rods thread ill start a 3rz relates thread in general car talk, the discussion is on
  2. #77
    1300hp? must have some huge drive train loss as it made 900hp @ the wheels on alcohol only a few weeks ago
    (edit its a 2rz!!!)
    KE38 - 2TG
    MS65 - 1UZ
  3. #78
    musnt be the same car then cause there is one in the states running that much power
  4. #79
    New Zealand
    Never bought anything from Paradise Racing, but based on their past performance I would look elsewhere for expertise. When they were using the 3TC they were well off the pace of what others were doing. Maybe good for a bit of research or even price checks but base any setup on advise from someone with better results from their own car.
    Callum
  5. #80
    what turbo is on the ARE car
    The boobs are back
  6. #81
    Rosewood
    gt42 from memory
    i know the GT35 is a nice match imho. Excellent midrange and top end.
  7. #82
    indeed richard,gt42 rings a bell from when i was last in there and asking 3 million questions haha, last time i went in to buy some speedflow fittings i asked him about the plenum he makes for the 3rz, and said 850, which i thought was fair considering the design and flow testing that has gone into it, its not just a bit of pipe with some runners...
  8. #83
    Junior Member Backyard Mechanic rodi's Avatar
    Apr 2007
    who sells rods? what are they worth?
    try atomic speedware got everything
  9. #84
    Toymods Tuner Backyard Mechanic Forcefed6's Avatar
    Got any more pictures of this.
    Should start this in the Members rides section, or get this one moved.... Either way, good work, and interested to see the outcome.
    Z10 Soarer - [email protected] ... 11's soon
    CHECK IT OUT HERE
  10. #85
    Apr 2007
    Quote Originally Posted by Forcefed6
    Mate i,m way to old, thought i was good getting this far. any way thanks for the encouragement
  11. #86
    Apr 2007
    Quote Originally Posted by -==L=a=N=c=E==-
    gt42 from memory
    anyone ever seen the ARE car do a time or is it just for dyno,s
  12. #87
    Anchorage AK
    ive got a prado engine. they run a front sump. the hilux 3rz is a rear sump. if you read above, this guy has cut the rear sump bulge and turned it around to make a front sump
    the sump i have is FKEN deep. it goes down to the depth of a normal front sump, then there is another drop which is about 4 inches.
    because of the diff being directly below it in the prado, the sump isnt very flat in the middle section. ill get pics of this soon
    here is one pic so far though. i think it would nearly drag on the ground if i left it as is hahahah
    Looks like the same sump as on the 1995 Tacoma 4WD I'm parting out. Most guys in the US use a 2WD T100 sump for a 3RZ to Hilux conversion. The T100 sump has a larger fluid capacity as well.
  13. #88
    May 2007
    Quote Originally Posted by rodi
    yeah u old barstard, why dont u tell them u how old u are, and u should be making a hot rod, not a corolla,
    u wont catch me old man! better come up and see u and bolt my stuff on so i can get it home to finish it be jambo
    get any pics b4 u pulled it apart?
  14. #89
    May 2007
    2.7lte 3rz didnt come out here till 9/1997 in aus, 22r was the engine b4 hand,
    that sump came out in 2.7 prado, hilux with IFS (not solid front diff) and even a light truck i cant remember the name of, 2rz hiace sump is the same as the front sump without the extra drop down,
  15. #90
    Anchorage AK
    The Tacoma sump won't work in live front axle, or right hand drop IFS trucks. People in the US converting live axle trucks to a 3RZ use the 2WD T100 sump. It still interferes with right hand drop IRS diffs tho. I looked at a 2WD Tacoma with a 2RZ last weekend. It has a sump similar to the 1UZ-FE in the LS400 Lexus. Would probably work in US 86-95 IRS trucks with a body lift. Not much joy for those who don't want to lift the body...
    Last Post: 03-05-2009, 06:47 PM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 12:43 PM
  3. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  4. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
