Lambolicas first pic seems to be the simplest, easiest method for hooking up twincharging. simple, effective, smooth transition when the SC turns off (and when SC turns off, remember that it stops pumpign air instantly!)
if you have two AFM's, and both are giving readings.. how do you add them together for the ECU to know what air flow is?
for cheapest and easiest... hook it up with turbo blowing into SC... heck, you don't even need to turn SC off once the bypass is fully open, as it will just be freewheeling in there (so you may as well.. but it'S easier not to have to re-engage it later)
OR, you could just run the perfect size turbo and minimise lag..
OR you could run a twinscrew SC and eliminate RPM and boost limits of the toyota SC, and have no lag like turbo...
all depend how much boost you want to run.... if you are after 30-40psi and still want something driveable, then twincharging is for you
do it.. you know you want to![]()
you definitely DON'T need the SC on at idle either...
70kw)
