Peter, do you know what that valve is actually for??
Omegaman,
Here's some pics
As you can see, the main hose (in red)has the T piece in it (blue). The T piece goes straight up through the runners up to the valve in the second pic (in blue).
Hope this helps
Peter
http://img.photobucket.com/albums/v2...r/MainHose.jpg
http://img.photobucket.com/albums/v2...eter/THose.jpg
the valve looks like it could be a aircon idel stepup. or some kind of polution re-circulation valve.
Its the A/C idle up Valve.
The other 2 small vacumn lines on the valve go back to a switch.
One line comes from plenum chamber to 'vacumn source' on the switch and the other comes from the valve to 'TP' on the switch.
Could be A/C idle up, but I have a wiring diagram that shows a vacumn switch coming off the Emission Control Computer as well. Not sure what it is though.
nah, get rid of it if you dont have ac, take out the hole valve and replace with NoS lol.
Hey everyone,
Just have a quick question about 18RG timing covers and all the bits around it.
I am just putting my RG back together (fixing an oil leak and decided to give it the once over again)
Anyway after getting all the timing chains on, I was trial fitting the timing cover and there are 2 holes that do not have anything that lines up on the cover.
One goes to an oil gallery and the other is just to bolt a guide to on the 18R.
So I pulled apart an 18R I have here and the guide that goes up to the top of the timing cover has an oil jet / squirter that bolts to it into these holes.
I have never had one of these on my RG since having it (well the 2 others I have don't seem to have them either)
So question is, should I use the oil jet from the 18R? or is there a different one for the RG that I am missing, or is everyone just not using it?
Page 4-23 Fig 4-67 of the 18R green book shows the guide I am referring to.
I will try and attach some pics...
Timing cover holes
http://picasaweb.google.com/lh/photo...eat=directlink
With 18R oil squirt temporaryily in place.
I'm holding off doing anymore tonight until some of you guys take a squizz
Dave
The 18RG has an oil squirter also but it is simpler in design. Only thing is I cant remember if it is in this spot or mounted higher in the head. The 18RG oil squirter is basically a hollow bolt with a small hole on either side of the bolt head to squirt oil horizontally onto the chain running up and down past it. I'll see if I can find a pick to show what I mean.
Glen
18RG oil squirter is mounted in the front of the head between the chain going up and the chain coming down. The 18R had a cam gear in this location and that is why its chain oil squirter was located in the top of the block. The 18RG just had a grub screw plugging the oil hole in the block I think.
Glen
Hey,
yeah I forgot to mention the oil squirter that was in the head is all good.
But figured I either need the 18R one in here, or I need to block it off.
If I don't, wont it let too much oil through (ie no restriction...)
So short bolt with thread sealer and a copper washer to close off the original 18R place?
thanks
Dave
hey all , just picked up a ra28 with a fresh rebuilt 18rg with a problematic head , even though the the head (111-8250) has been rebuilt twice over the last 6 months the previous owner has stated that it has gone soft? and i would need another 18rg head.
is this a common problem?
regards des
My little brother had this problem with his 3S.. apparently being aluminium if they overheat (for too long/ or too hot?) the material can go soft... we just had to bin the soft one and get another... shouldn't be a problem with the 18RG, they regularly sell for $50 - $100, check out the classifieds section, i'm sure there's one floating around atm...
'77 RA28LT #2 ← 2.2L 18RG...
What are the symptoms of it going too soft?
(\__/)
(")_(")
Symptoms from a engine running point of view? i have no idea... we found that the 3S was too soft when we took head to get it checked out for warpage after it overheated... so i guess in this case it was all the typical overheated engine symptoms, but how you'd know it was soft otherwise, i don't know...
there is a way you can fix it, but it costs, if it is not a special head, get a new one, it will give you a chance to make better head.
sam.
