Page 133 of 392 FirstFirst ... 3383123131132133134135143183233 ... LastLast
Results 1,981 to 1,995 of 5875
  1. #1981
    Junior Member 1st year Apprentice RA40peter's Avatar
    Jun 2006
    Omegaman,
    Here's some pics
    As you can see, the main hose (in red)has the T piece in it (blue). The T piece goes straight up through the runners up to the valve in the second pic (in blue).
    Hope this helps
    Peter
    http://img.photobucket.com/albums/v2...r/MainHose.jpg
    http://img.photobucket.com/albums/v2...eter/THose.jpg
  2. #1982
    Peter, do you know what that valve is actually for??
  3. #1983
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    the valve looks like it could be a aircon idel stepup. or some kind of polution re-circulation valve.
  4. #1984
    Its the A/C idle up Valve.
  5. #1985
    Jun 2006
    The other 2 small vacumn lines on the valve go back to a switch.
    One line comes from plenum chamber to 'vacumn source' on the switch and the other comes from the valve to 'TP' on the switch.
    Could be A/C idle up, but I have a wiring diagram that shows a vacumn switch coming off the Emission Control Computer as well. Not sure what it is though.
  6. #1986
    south australia
    nah, get rid of it if you dont have ac, take out the hole valve and replace with NoS lol.
  7. #1987
    Hey everyone,
    Just have a quick question about 18RG timing covers and all the bits around it.
    I am just putting my RG back together (fixing an oil leak and decided to give it the once over again)
    Anyway after getting all the timing chains on, I was trial fitting the timing cover and there are 2 holes that do not have anything that lines up on the cover.
    One goes to an oil gallery and the other is just to bolt a guide to on the 18R.
    So I pulled apart an 18R I have here and the guide that goes up to the top of the timing cover has an oil jet / squirter that bolts to it into these holes.
    I have never had one of these on my RG since having it (well the 2 others I have don't seem to have them either)
    So question is, should I use the oil jet from the 18R? or is there a different one for the RG that I am missing, or is everyone just not using it?
    Page 4-23 Fig 4-67 of the 18R green book shows the guide I am referring to.
    I will try and attach some pics...
    Timing cover holes
    http://picasaweb.google.com/lh/photo...eat=directlink
    With 18R oil squirt temporaryily in place.
    I'm holding off doing anymore tonight until some of you guys take a squizz
    Dave
  8. #1988
    Nov 2007
    The 18RG has an oil squirter also but it is simpler in design. Only thing is I cant remember if it is in this spot or mounted higher in the head. The 18RG oil squirter is basically a hollow bolt with a small hole on either side of the bolt head to squirt oil horizontally onto the chain running up and down past it. I'll see if I can find a pick to show what I mean.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  9. #1989
    Nov 2007
    18RG oil squirter is mounted in the front of the head between the chain going up and the chain coming down. The 18R had a cam gear in this location and that is why its chain oil squirter was located in the top of the block. The 18RG just had a grub screw plugging the oil hole in the block I think.
    Glen
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  10. #1990
    Hey,
    yeah I forgot to mention the oil squirter that was in the head is all good.
    But figured I either need the 18R one in here, or I need to block it off.
    If I don't, wont it let too much oil through (ie no restriction...)
    So short bolt with thread sealer and a copper washer to close off the original 18R place?
    thanks
    Dave
  11. #1991
    Oct 2008
    hey all , just picked up a ra28 with a fresh rebuilt 18rg with a problematic head , even though the the head (111-8250) has been rebuilt twice over the last 6 months the previous owner has stated that it has gone soft? and i would need another 18rg head.
    is this a common problem?
    regards des
  12. #1992
    My little brother had this problem with his 3S.. apparently being aluminium if they overheat (for too long/ or too hot?) the material can go soft... we just had to bin the soft one and get another... shouldn't be a problem with the 18RG, they regularly sell for $50 - $100, check out the classifieds section, i'm sure there's one floating around atm...
    '77 RA28LT #2 ← 2.2L 18RG...
  13. #1993
    What are the symptoms of it going too soft?
    (\__/)
    (")_(")
  14. #1994
    Symptoms from a engine running point of view? i have no idea... we found that the 3S was too soft when we took head to get it checked out for warpage after it overheated... so i guess in this case it was all the typical overheated engine symptoms, but how you'd know it was soft otherwise, i don't know...
  15. #1995
    south australia
    there is a way you can fix it, but it costs, if it is not a special head, get a new one, it will give you a chance to make better head.
    sam.
