Page 382 of 392 FirstFirst ... 282332372380381382383384 ... LastLast
Results 5,716 to 5,730 of 5875
  1. #5716
    Sydney N.S.W
    Has anyone got a easy solution for adding hall effect wheel to the GEU crank?
    There is the MSD aluminium wheels on ebay that im concidering bolting to the front of the balancer. (see link)
    http://www.ebay.com.au/itm/MSD-Repla...item1c529337ec
    The Harmonic balencer is about 14cm (5") in diametre. If i bolt a upto 18cm (7") wheel on the front, then i can place the sensor to read behind it, as opposed to
    the top edge...?????
    i can easliy adapt the sensor, but the wheel is another story. I've seen toothed trigger wheels machined and added, but i want an easy fit for the use of
    hall effect magnets.
    Any solutions?
    I've finished wiring my Haltech up, with just this the fix and then i'm able to start it.
  2. #5717
    Sydney N.S.W
    i think i've answered my own question.
    Whats to say i cant use a 8-10 mm thick aluminium wheel spacer. Have it cut to fit around the harmonic balancer or screwed or glued to the back/front of it.
    even if you can machine a round lip on the back of the balancer and fit this on.
    drill the 2 holes 180 deg from each other and glue the special magnets in place.
    its like $20 for 2 spacers...beats buying and modifying a MSD wheel..
    im going to try this on the weekend.
    doable????
  3. #5718
    Sydney N.S.W
    Since theres no ideas on Hall effect wheels, i'd thought i'd attempt my idea above.
    The only other thing i had to do was grind down the pointer on the chain giude cover.
    Pics tell it all.
  4. #5719
    Aug 2008
  5. #5720
    Sep 2007
    Georgia
    Quote Originally Posted by jabbatron View Post
    Just keep in mind that ring behind the first V groove is the rubber mounted harmonic balancer, the V's themselves are solid mounted tho.
    +1 also when the rubber fails, and they do, your timing will be out of range.
    I have had to have those Pulleys repaired from a guy here stateside when I owned a Datsun Fairlady and its pulley failed (Worn rubber spun the outside belt pulley and eventually fell off while driving, not cool.) That Center hub is a solid mount, so attaching it their will keep you honest within your modification.
  6. #5721
    Sydney N.S.W
    Yep, I understand the what yr saying. But this is a temporary solution. But the best I can think of at this stage of the build.
    I've seen toothed wheels placed here after some modifying/machining, which they seem be travelling fine to date.
    Till a better solution comes up, this will get me to the tuning stage, where the roar will come to life and my enthusiasm will be at a stage of all out go for it.
    Its been too long.
    thanks guys.
  7. #5722
    Most people have attached the toothed wheel to the front of the harmonic balancer i believe.
  8. #5723
    Sydney N.S.W
    Quote Originally Posted by The Witzl View Post
    yes, i've seen both, front and back.
    Well. My setup of the Hall effect works, as in when you turn the motor by hand, the readings for 1st magnet read 3.3 volts till it passes the 2nd magnet, then zero volts for 180 deg.
    So i'm happy with that. Need a new fuel pump now...errr. then i can attempt start up.
  9. #5724
    Sydney N.S.W
    gents. Is there an dual Igniter that can be compatible with Haltech e6k, that can also be used to send a tacho signal to the original ra28 tacho?
    Im trying for a batch fire wasted spark, using two coils, but my current EMS igniter does not seem to be compatible with haltech.
    what did you guys use back in the day?
  10. #5725
    You should be able to use something like a Microleb X4 ignitor.
    As for tacho output.... yeah that's a pain, you should get your ECU to provide that signal, and then use a tacho booster to drive the stock tacho.
  11. #5726
    Sydney N.S.W
    im going back to dizzy, cause the ignition set up is driving me nuts.
    I was going to give this ago for tacho, but since I can get RPM signal from -ve COIL, I wont bother with relay.
  12. #5727
    Sydney N.S.W
    just before i go back to dizzy.
    hall effect cas. at 70deg BTDC and home signal at 40deg btdc...sounds about right? in short.
  13. #5728
    Sydney N.S.W
    made two types of tacho boosters last night.
    will give them a try on weekend.
    im assuming that the resisters need to be soldered in the correct direction, would i be right?
    i looked at the colours and think i put them in the right direction.
  14. #5729
    Resistors aren't polarised man.
    The diode is though, the stripe on the diode souls be in the same orientation as the line on the schematic symbol.
  15. #5730
    Sydney N.S.W
    Quote Originally Posted by RA35GT View Post
    But doesn't the resistors at least have a current flow from + to negative. hence why i asked which side is which, by sight.
    the resister i used above had 5 colours, so i couldnt tell which side was which.
    i will make another booster tonight, this time taking a good look and checking with multimeter that all is well as i go.
    the diode i do understand now. i'm started reading Witzl's link- http://www.autoshop101.com/ and learning heaps.
