Page 348 of 392 FirstFirst ... 248298338346347348349350358 ... LastLast
Results 5,206 to 5,220 of 5875
  1. #5206
    Sydney N.S.W
    This is my last weekend to solve my cutting out problem, before toyfest.
    I have a feeling that in the rebuild a while ago that maybe the pump drive shaft which turns the dizzy is out by a tooth or 2.
    If the cams are set correctly and the crankshaft is set at TBC, could the dizzy after a few rotations not align, therefore not fire?
    Keeping in mind, that the dizzy is set up at 10 deg BTC and the rotor about to fire...this has been adjusted as testing also.
    see the diag attached..
  2. #5207
    Top End
    on a normal 18R its a little bit of an issue as the dizzy shaft is keyed to the oil pump and if you have a
    dizzy with the retainer bracket cast as part of the housing you can only turn it so far but in my
    experience if you have a dizzy with the seperate clamp you can rotate it 360deg and position it to
    compensate its even easier on an 18RG as the dizzy isnt tied to the oil pump.
    i have seen dizzys turn while an eng is running but due to not being fastened proper
    provided the mechanical cam/piston/crank timing is correct then it should be possible to adj
    the dizzy to suit even a cast bracket dizzy (just have to take it out and turn a tooth)
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  3. #5208
    Top End
    i will asume you are using electronic ign ?
    get an old points type dizzy and check where the shaft is in relation to TDC compression the points should be just about to fire number 1
  4. #5209
    Sydney N.S.W
    Zammo, going by what you mentioned. If all is setup correctly, really it shouldn't matter. if the dizzy at TDC is about to fire, then all is good.
    Damn. then it seems thats not my problem. Ill go back and check the loom.
  5. #5210
    Jun 2010
    New South Wales
    Hey Guys,
    Attached are a couple of photos of the oil pump on my 18RGU and remote oil filter. Is this a standard set up?
  6. #5211
    What's pictured isn't your oil pump, that's in the sump.
    What you have is not standard, someone has fitted a relocation kit at some point in the last 35 years.
  7. #5212
    Junior Member Grease Monkey Rens's Avatar
    Nov 2010
    Dry sump set up maybe
  8. #5213
    Can't be dry sump. There isn't a storage tank. Just an old dodgy filter relocater.
  9. #5214
    Jun 2010
    New South Wales
    Quote Originally Posted by lilcrash View Post
    No dry sump. It has the normal centre bowl sump. Why dodgy? Should I get rid of it?
  10. #5215
    Personally I would be re mounting it and get some new hoses to make it look tidier.
  11. #5216
    Sep 2013
    CA
    Hi all,
    Just wanted to ask all of you seasoned 18rg fans a question in regards to the EFI version and the amount of boost it can handle on stock internals? I have been searching this 260 page thread for "stock efi boost" details and seems most of you are way built up! My plan is to run a 3TGTE ECU (which I'm currently looking for) with the 4agze injectors and t3 turbo with full 3" exhaust.
    Thanks in advance for any guidance
    -Nick
  12. #5217
    Top End
    LOL might wanna try the Turbo RG thread (yes its such a special engine it has its own)
    http://www.toymods.org.au/forums/tec...ce-manual.html
  13. #5218
    Aug 2008
  14. #5219
    Top End
    dont forget old mate with 9sec yellow corolla that had meth turbed RG i cant brain today his name is elluding me.
  15. #5220
    Quote Originally Posted by Zammo View Post
    Peter Kiprios I believe you are talking about.
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
