Page 347 of 392 FirstFirst ... 247297337345346347348349357 ... LastLast
Results 5,191 to 5,205 of 5875
  1. #5191
    Aug 2008
  2. #5192
    Sydney N.S.W
    yep, no probs there....
  3. #5193
    Aug 2008
  4. #5194
    Sydney N.S.W
    As per diag. I got power from red wire battery and orange and yellow for the injectors.
    remember when i did a test and i had power to each injector, so in saying that, the ecu is not earthing it through the yellow and orange wires....
    the loom is grounded ...
  5. #5195
    Aug 2008
  6. #5196
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Is anybody else still running carbs on their 18rg?
    The redline manifold and redline linkages and my 45mm webers are having some slight issues
    The runners on the manifold are not long enough the mounting point for the linkages was too close to the head and the linkages were touching and not moving properly
    I filled the mount holes and moved them further out. so that sorted that issue
    Now my problem is that to get at the vacuum outlet for the brake booster I would need a right angle fitting, But i would not be able to screw in as there isn't enough room to turn it between the two flanges
    I have now gone down the route of getting vacuum from all 4 runners using a very expensive array of speedflow fittings.
    Now the problem with that is that the fittings are too tall coming off the manifold and are hitting the underside of the head
    My plan is to make a 15mm aluminium "flange spacer" to space it all out and ressurect this issue
    Question 1: Does anybody have a cad drawing of the intake flange?
    Question 2: Who else has used a redline manifold and/or had similar issues?
    Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  7. #5197
    Sydney N.S.W
    Unhappy Re: For the love of a tractor engine: The life and times of the 18R-G
    Quote Originally Posted by jabbatron View Post
    Check that you have power while cranking (assuming your using switched not constant power from the battery), one of the acc power supplies gets switched off while cranking. Otherwise *shrug*, send the ecu back to me and ill do some testing i guess.
    i didn't get a chance to work on it on the weekend. I'll give it another go one night this week.
    i want to sort this out next week end, so if anyone who can diagnose this sort of stuff, who wants to pop past, over the weekend and have a crack at it.
    Let me know (PM me). its in the Canterbury area, Sydney 2193.
    there's a case in it for you, to start with (minimum wage) for a diagnosis.
    if sorted and any hard labour involved will be compensated. I need fresh eyes on this.
    it's simple, i know it. i'm thinking timing. AHHHhh.
    if yr really keen, you can wire in my EA alternator for a price. as i'm over working on the car.
  8. #5198
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    Has anyone found a source for the half moon seals I remember reading something about Mitsubishi ones a while back
  9. #5199
    I bought genuine ones from Toyota a few years ago. Not sure if you can still get them. Would have to check up on the part number, but it is in this thread somewhere, so searching could help you.
  10. #5200
    Feb 2012
    Sa
    And search works sometimes part no 11183-88260
    $16 each from toyota
  11. #5201
    ok fellow 18rg lovers, i just want an opinion on something. i purchased an 18rg flywheel from a forum member interstate, it arrived cracked badly, the forum member isn't responding to my pm, since i purchased this flywheel i can no longer afford to get my 18r flywheel machined, is it actually necessary to machine the flywheel when installing a new clutch?
  12. #5202
    Got any photos of the cracks? It's always advisable to machine the flywheel to ensure you get the best friction plate to flywheel contact.
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  13. #5203
    I will upload some pics tomorrow. I'm in bed at the moment. But there is 3 cracks that go right through the friction surface.
  14. #5204
    Aug 2008
  15. #5205
    Surface cracks are pretty normal on a friction surface. It depends on how deep they are as to whether or not they are a problem. If the are shallow and refacing removes them, no issue. If refacing does not remove them, then the flywheel is cactus.
    As Jabbatron said though, not surfacing the flywheel will do bad things to the new clutch very quickly.
