Page 249 of 392 FirstFirst ... 149199239247248249250251259299349 ... LastLast
Results 3,721 to 3,735 of 5875
  1. #3721
    Junior Member Backyard Mechanic egamirrorim's Avatar
    Thanks guys
  2. #3722
    Dec 2010
    Ilmajoki
    OK
    maximum RPM of 18rg engine?
    Im trying to rev my engine over 9000rpm.
    My engine:
    18rg head titanium valves, orginal springs.
    11mm lift cams.
    Stantard 18R crank.
    pistons forged aluminium-titanium matrix (300g)
    carillo nascar conrods.
    steel flywheel.
    tilton clutch.
    What part of engine is first one to blow?
    What thing needs to take in concern when reving this hi rpm?
  3. #3723
    Quote Originally Posted by jsskangas View Post
    OK
    My engine:
    11mm lift cams.
    Stantard 18R crank.
    steel flywheel.
    tilton clutch.
    I'm guessing mains caps? the rest of the gear looks pretty solid, assuming ARP fastners?
    My old 18RG turbo with stock rods (linished then shot peened) was revved to 8000+rpm on a regular basis and was fine.
    The big weakness for a boosted RG is the OEM head bolt, so again ARP heads studs would be the go.
    Sounds like a serious motor. Agreed with Justen, ARP fasteners all round would be a good start (rods, mains, head and flywheel). I would also get your mains line bored (mine were slightly out), and when they torque up the ARP fasteners on the big ends, they will need to bore your rods as they will go out of round on the big end.
    Have the block bored to suit the pistons, increase the oil pump pressure (shim up the bypass) as the general rule of thumb I have been given is 10psi of pressure per 1000rpm when hot for a performance motor (my bottom end was built for 9000rpm, however I think the cams and turbo will be too much of a restriction to get there).
  5. #3725
    Dec 2010
    Ilmajoki
    Hello
    Is there eny limitations using 18R / RG oilpump.
    max pressure, max rpm ect...
    Have enyone tested how much can 18R pump produse pressure before failure?
    Here is my project:
    http://www.toymods.org.au/forums/sho...8F1%29-to-KE20
  6. #3726
    Factory standard is 60psi hot. I can confirm that a standard 18RG pump with 30 years of wear and an offshoot to a turbo will hold that 60psi when hot. I haven't shimmed up the bypass, so can't comment on increasing the pressure past that just yet.
  7. #3727
    Aug 2010
    S.E.Q.
    [QUOTE=jsskangas;1334281]Hello
    You do have the 30 mm high RG pump I take it. I would be sus on using the 25 mm one from an RC.
    Owen, the normal one.
  8. #3728
    Dec 2010
    Ilmajoki
    S. Lowlux: I have bigger RG pumps but they are not for sale.
    They are hard to find in Finland too.
  9. #3729
    Aug 2010
    S.E.Q.
    jsskangas, mate we seem to have an Aussie english to Finnish language missunderstanding. My comment, "I take it" did not mean that I am wanting to buy the pump. What it means is that I take it as read, or I take it as a given thing that you are using the larger pump. Hope that clears your understanding.
    I have the larger pump myself & make even bigger ones, look back in this thread.
    Owen.
  10. #3730
    My engine:
    11mm lift cams.
    Stantard 18R crank.
    steel flywheel.
    tilton clutch.
    Original valve springs??
    No way will you get 9k out of those.
  11. #3731
    Dec 2010
    Ilmajoki
    Quote Originally Posted by S. Lowlux View Post
    Owen.
    OK, Yes of cource Im using bigger pump.
    Now I get what you mean by "I take it".
  12. #3732
    Dec 2010
    Ilmajoki
    Valves are half of weight that orginals are.
    I think this compensates lack of spring load.
    I have nascar springs but these need too much mods at this time.
  13. #3733
    spank that naughty.. Grease Monkey
    Aug 2010
    country Victoria
    question for the gurus... what sump do i need to get the 18rg into an 83 lo lux
    what car might i find one in ?
    ( see post in want to buy )
    Remember this is a recreational activity ......
    we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
    the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
  14. #3734
    You would need the sump from an 18R powered Hilux of the same year - as this was the one which was made to suit your vehicle. 18R-C sumps are identical to 18R-G items.
  15. #3735
    Aug 2010
    country Victoria
    my lux was only up to 12 r ( 1500 cc) at that stage, an 18 r would have been a great option ,
    cutting and shutting this weekend it is
