Page 12 of 392 FirstFirst ... 210111213142262112 ... LastLast
Results 166 to 180 of 5875
  1. #166
    Don't try it on a turbo engine though!
  2. #167
    Hasn't Cliff Hansen done a 92.5mm bore blowing in 21 pounds?
    (\__/)
    (")_(")
  3. #168
    i think cliff got the capacity with some clever selection of crank, rods and pistons?
    update:
    i was wrong - Fast Fours article, date/year unknown:
    -16R Rods
    -22RE dished (92.5mm) (resulting in 6.8:1 comp ratio)
    -eccentric ground 18R crank to add 3.5mm stroke
    total engine capacity lifted to 2.4 litres.
    note: he is running a very efficient W2A intercooler and boost is a maximum of 21psi.
    Last edited by thechuckster; 27-02-2006 at 12:00 AM. Reason: edited for accuracy and spelingk
  4. #169
    YUKKY!!!! How the hell could you drive something with such low compression??
  5. #170
    keep it on boost
    The boobs are back
  6. #171
    i'd prefer something with some compression thanks.... EWW!!
    My 18R-GTE will end up around the 8-9:1 compression ratio, much better
  7. #172
    Besides, what difference is it going to make if you take an extra half a millimetre out of the bore? There is well enough there to have a 93mm bore with a turbo.
    I really do wonder how the hell he ground the crank to gain 3.5mm of stroke
    If he had done it the conventional way of just offset grinding the crank he would have had to use +.320" bearings and ground the crank .180" below its original size.
  8. #173
    I guess 16R rods have a smaller big end.
  9. #174
    they dont, cause u r supposed to use 16R rods with 22r crank
    16/18/20/21/22R big end bearings are all the same
    The boobs are back
  10. #175
    Its a mystery then. Unless its a custom billet crank. which would have cost 5 g's. Or dramatically resized the 16r rods.
  11. #176
    Or the magazine article was completely wrong. It certainly wouldn't be the first time.
  12. #177
    dont be silly, that never happens
    The boobs are back
  13. #178
    cliffs car DOES use the 22r/16r combo
    The boobs are back
  14. #179
    Is there a way i can contact Cliff? Regarding RA28 matters. Please PM if so.
  15. #180
    Yeah, show up to a Toyota Car Club of Qld meeting.
