Originally Posted by
o_man_ra23
jedrock, welcome. What head did you say you had?? 88250 or 88253, or is it a 2T-G?? If you had it bored to 2.0L, then you didn't have it bored much, as they are 1968cc from factory.
Now, causes of increased heat can be many and varied. First one to find is a leak... check the level in your radiator, does it go down at all??
Second, it's your summer right?? Are you having a heat wave?? (I am not joking here, this can be a serious contributer to the reduction of cooling capabilities), and you could well be using an air conditioner you don't use in winter (if you have air con)
Water pump - they have a little hole on the bottom of them halfway between the inner and outer bearings. If there is green (I am assuming you are using coolant... if not, start using coolant as that may well be your problem) or red (depending on what brand/mix you use) colour coming out that hole, or a rust trail, then you have a stuffed water pump. These things are pretty hardy, and its basically just the bearings that fail.
Next item is thermostat. Take it out, put it into a pot of boiling water (use and old pot or your mum/missus will kill you) and see if it opens. If it remains in the same position, or hardly moves, replace the thermostat. If you don't have a thermostat, that is why you are overheating, so you should install one.
Radiator cap... is it in good order and still functioning/sealing correctly?? A radiator cap that is in poor condition can cause overheating
If you have air con... make sure there is nothing stuck between the air con condenser and the radiator... leaves etc often build up in there.
If you have an auto, check your transmission fluid level and quality. A poor performing auto will cause overheating.
Check your oil. It should be fairly clean, not smell burnt, and be less than 6 months old. If not, replace the oil and filter. If you don't normally change your filter every oil change, smack yourself on the arse, this is a must.
Air filter, a clogged one can cause overheating.
Spark - check your ignition timing against manufacturer specks, this can be a cause of overheating.
Revs, if you run around at full revs all day, try driving sedately and see if this improves things.
Temp sender - is this still in good order?? A poor temp sender will show a false reading, and the summer you are in could lead to the engine bay feeling apparently hot.
Brakes, if they are dragging, then your engine has to work harder and will overheat. Lift the car onto stands, take off the handbrake and foot brake and put it in neutral. All wheels should be able to move fairly freely (you will notice if one is dragging)
Mixture, if your running lean you will run hot.
Hope I have covered as many possibilities as I can... but you really need to start narrowing down your search.
