I'm actually using 3 ohm injectors. But the website for EMS says 3ohm resistance = set to 2.4 so that's right anyway. which is weird. I thought that GZE injectors would be different (as that's what it's from, a 4agze)So you are actually using 2.4 Ohm injectors? Because if you are using high impedance ones you'll be getting very different behaviour.
Yeah I guess I should do that. argh. pitaI think you need to set the engine to TDC Comp. and refit the dizzy and start again. This way you KNOW it isn't out by a tooth and it must start with this setup. You just give it a tiny bit of advance by eye (so that it's not set to 0°) and try to start it.![]()
