Results 16 to 22 of 22
Thread: machining 1ggte harmonic balancer
    Default Re: machining 1ggte harmonic balancer
    jayem,what car is that in and is that a 1ggze? looks like no gte ive seen before...
    i think im gonna get mine done, as it is out of the car at the moment...
    ok, im gonna run with the idea of getting it machined and see if anyone gets what im on about...
    with the 1g in my ke70, when you jack the front end up and the wheels drop, the swaybar pivots upwards and hits the pulley, which gradually wears it away:
    that was one after 10 years...so it doesnt happy in a hurry, but i still worry about it.
    so, would it be possible to get the pulley machined down to a smaller diameter?
    and would it cause any great problems doing this, like spinning water pump or alternator too fast?
    tis just a thought. cheers, andrew
    Junior Member Grease Monkey Jayem's Avatar
    suomi
    You might get away with TT132 (XT130?) swaybar. It doesn't curve front like KE70 sway bar does. Otherwise it's similar in measurements but 24mm thick. KE70 bar is 23mm.
    TT132 sway bar
    Another pic
    Car in pics I send is my TT132 Corona with 1G-GZTE.
    http://img.photobucket.com/albums/v6...1520Medium.jpg
    http://img.photobucket.com/albums/v6...2520Medium.jpg
    Sorry I dont have more recent pics...
    Shouldnt be a problem, machine off and get balanced.
    Machining the crank pulley to a smaller diameter will result in the ancillary equipment spinning slower. Whether thats too slow or not, Im not sure on the dynamics of your ancillaries.
    jayem, do those sway bars fit on ke70's?
    like, each end is in the right spot etc.
    might have to check that out.
    dunno whether it will clear my sump, but it may be worth a look...
    and jayem, you are the fin yes?
    know of any clean 2 door ke70's for sale that i could import to aus?
    cheers, andrew
    and are they head studs in the gze?
    and did you ahve to relieve the head to fit the nuts?
    what ones did you use?
    cheers, andrew
    To stop pm's asking for it.
    Ross tuffbond harmonic balancers
    ADDRESS ::
    2/16 FORGE STREET,
    BLACKTOWN. NSW 2148
    AUSTRALIA
    :Tel : [02] 9676-1466
    :Fax: [02] 9672-8939
    Friends
    suomi
    I found a pic of KE70 sway bar. Here you can see the curve. Yeah it's otherwise similar. Both ends are in the same place compared to where the bush is. Only actual difference is that center part where's the curve in KE70 bar and the 1mm difference in thickness.
    Yeah I'm from Finland. Here are some Corolla's for sale in Finland:
    klik
  1. harmonic balancer blues
    By SIKPUPY in forum Tech and Conversions
    Last Post: 15-05-2007, 09:41 PM
  2. removing the harmonic balancer on 1jz
    By soarerchic in forum Tech and Conversions
    Last Post: 16-10-2006, 12:21 AM
  3. harmonic balancer ??? !!!!!
    By 1jzracing in forum Tech and Conversions
    Last Post: 04-04-2006, 01:30 PM
