Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 76 to 90 of 133
Thread: turbo upgrade for 1GGTE
  1. #76
    Junior Member 1st year Apprentice 16OTU's Avatar
    Default Re: turbo upgrade for 1GGTE
    Well from a totally stock 2nd engine with all bolt ons, I made 350rwhp running 23psi and use to shift at 7500 but limited to 8500. It was a T04R. That motor lasted more than a 1.5 yrs and just got a bit smokey.
    Then I put a 66mm front wheel and a set of forgies and turned the boost up to 27psi and now make 420rwhp. Then got head flowed and bigger valves and made no more power. Next looking into some cams for it.
    So it can be done fairly easy as long as it has the fuel and is tuned right. When I 1st got it going it made 300rwhp and run 11.8@121mph in the gem.
    Ron
    [email protected]
    No NOS, No Slicks, No C16.
    442RWHP, More to come!
    My Space & Photo's
  2. #77
    Haven't read through yet, so hopefully this isnt to dumb. But last night i was on the toilet pondering many thoughts..!
    I was thinking, how bad an idea would it be to run a twin turbo set up comprised of one ct12 and one ct26? Or like a ct12 and a t25g or t28?
    Purely for wank factor and slightly to do with keeping lag down and boost up, i wanna stay twin turbo... I just like the ring to it!
    Any thoughts?
    Jase
    JZA023
  3. #78
    waste of time in my opinion smokey.
    with the technology of ball bearing garrett turbos i really dont think its needed.
  4. #79
    Quote Originally Posted by TheToyman75
    You can always give them to me
    I've got a couple of ideas yet to work out where it's being restricted before they go anywhere
  5. #80
    hey ron, what was the diff ratio in your car?
    cheers steve,
    1ggte, 11.22 @122mph
  6. #81
    Standard gemini ratio 3.9:1
    [email protected]
    My Space & Photo's
  7. #82
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    Hey 160TU I am getting some cams this following week for the 1G from Waggot cams. I am sending mien away and then send them all your specs, gear ratio, stall and the reground you a custom set from your cams. Also big help is if you get adjustable cam gears as you get full use of the new cams and easier to dial them in. If you interested PM maybe he can do better on the price with two sets. I am paying $800 for a set.
    My engine done 174 thousand km but compression at 162 thousand was a lovely 155 on all cylinders except two that showed 150 across the board so the rings are still in good nick. Should be good for 200rwkw with cams I hope but the auto will hinder the dyno numbers a bit...
  8. #83
    victoria
    Any thoughts?
    Jase
    you should have let that idea go with the rest of your cargo in the toilet
  9. #84
    800 for a set of cams reground sounds pretty good to me..
    ill keep that in mind for when i get mine done
  10. #85
    Seen, but not heard Grease Monkey fingers's Avatar
    So what is the general consensus here on sizing; what is the point where a turbo on a 1G-GTE where a turbo becomes too large?
    Obviously this is very subjective and will depend on the person preference, but I'm interested in opinions from 1G owners who've the single turbo route.
    People have mentioned the GT3076; Seems to be pretty resposive on a 1J. Does it really take that much longer to spool up?
  11. #86
    tasmania
    hey guys,
    seems like a few good ideas out there!
    few questions.. what about after market computers? do most people run them when they go single? or is it okay to run the standard?
    cheers!
    rollsy
  12. #87
    Junior Member Backyard Mechanic SIKTOY's Avatar
    I think that for a good responsive turbo you would use a .58 exhaust housing but you would be limited to power in the top end
    But if you want big power and can handle a bit of lag use a .84 exhaust housing
    The KKR range that OTMOTO (sponsor) import are a good cheep option
    My2c
    Ben
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
  13. #88
    will run good on a standard comp but too get the most an aftermarket comp is the go
    cheers steve,
  14. #89
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    has any one ran a AC delco ecu on a 1G??
    i will be using a micotech because i know a guy that can tune them real good but he isnt local,
    but if any one has used a delco ecu i also know a guy that can tune them good too
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
  15. #90
    Forum Sponsor Conversion King
    3076r would come on at about 3800-4000 with a .63 rear.
    with gears maybe faster, then cams and springs quicker again.
    most depends on manifolding and tuning and the rest of your support systems come into play.
    you should get to the 280kw mark with this turbo at about 23-26psi depends on if the bottom end handling the boost and revs.
    other than that its bigger turbo and lots of lag.
    Last Post: 11-10-2014, 12:02 AM
  2. Turbo Heat Shielding
    By MarioM in forum Tech and Conversions
    Last Post: 21-05-2007, 09:18 PM
  3. 3sgte Turbo Upgrade - WRX turbo?
    By medwin46 in forum Tech and Conversions
    Last Post: 25-11-2006, 06:02 PM
