Page 8 of 9 FirstFirst ... 6789 LastLast
Results 106 to 120 of 133
Thread: turbo upgrade for 1GGTE
  1. #106
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    Default Re: turbo upgrade for 1GGTE
    Hey peoples thanks for all the input. My setup in detail is as follows:
    Engine:
    Blitz Hi flow Gen 3 turbos
    Full 3’exaust
    2.5 metal IC piping
    1G-HKS cooler (Bolt on replacement)
    Forcefed Custom Adj. Cam gears
    Waggot Reground cams (not yet sorted as my cams have been posted yesterday)
    CRY o2 Intercooler spray
    Head has been cleaned and ported (just to remove any factory defects)
    New Valve stem seals but stock valve springs
    New leads, Cleaned injectors and anything that needed attention or was getting worn/old was replaced.
    Piggybacks:
    Apexi NEO (16 point fuel adjustment)
    Apexi SITC ( I know it’s a bit crude)
    Blitz DSBC (Very happy with this, holds boost steady as rock, no boost drop at the top end and spools it faster)
    Trans/Diff:
    Low km non abused A340E
    2800 stall
    MV 1.5 Shift kit
    4.44 rear diff gears (lowest that z20 auto came out with)
    That about it... I am waiting to get the cams done and put in the gears and hit the dyno. I have a spare 1G in the shed that’s only done 50,000km so if she blows I'll just swap engines.
    Toyman thanks for your input, if I knew about the Xede processor earlier I would have considered it. I think it would be better especially in the timing department then the SITC which is old school and pretty crude. I just hope its affective.
    Chris stall converter was the first thing on my list as I know from my SB chev it makes a huge diff. Unfortunately it does not flash to the stall speed like the Chevy and when loaded against the brakes to 2700ish it bogs down for some reason. I have driven other stock 1G z20s and they weren’t that poor off the line as mien. My only idea left is that the TVIS is stuck open and I will be checking the vacuum actuator to see if it closes tomorrow. This would go to some way of explaining my poor off boost performance (I hope).
    Otherwise I am completely out of ideas.
    As for the cams like you said it will be a compromise with more lift and trimming some top end gain for better midrange and bottom end with cam gears. That’s the theory for now.
    If I find that the TVIS is the cause of my lack of bottom end I will do the opposite and go for midrange and more peak power.
    Sorry for the loooong post.
  2. #107
    Quote Originally Posted by TA-022
    would this not require a 180 spin on the rear turbo?
    otherwise i cant see enough space to make twin dumps down the guts that would do much better.
    but please prove me wrong ... more power is good power!
    Nathan,
    The twin dumps are being designed as a bolt in upgrade for the stock turbo's and pipework. The basic layout has already been set out and it looks promising. The only part of the pipework that will need revision is of course the exhaust. Don't hold your breath on the time line but it will happen.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  3. #108
    no rush .. only just got mine running ....no mods for a while yet
    Black Betty >HERE!<
    (\__/)
  4. #109
    So they're ala 1JZ Y-pipes? Any ballpark for costs, or is that a "depends" question?
  5. #110
    Forum Sponsor Conversion King
    wont be Y pipes , it will be two seperate pipes for about 30cm then they will join.
    price,?. how long ,couple of weeks. im sure rod will throw up pics.
    as for cams not bringing a turbo on earlier. try a set of hi lift 256 or 264 cams and see the diff , if they are adjusted correctly it should bring it on earlier as well as raise peak power.
  6. #111
    Thanks for the tip Road runner. I was under the impression you can only have better bottom end and same top end and not both. That sounds promising if i could have my cake and eat it
  7. #112
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Quote Originally Posted by JustCallMeOrlando
    Hehe, that goes against my "not spending any more money on this car" think pattern. Any improvements I make will come through utilising shit I have laying around
    Coffs "tight arse"Coffs
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
  8. #113
    Worlds Fastest 1G Backyard Mechanic
    Well to throw my 2c into the ring, I have fitted almost every turbocharger from a 3071 up to a T66 to a 1G, and helped with both Ron's gemini and Jamie's soarer. Here are a few facts:
    If you want to make much more than about 250kw, forget trying to use the factory auto, it simply won't cut it, this is from disassembly and component strength inspection, and personal experience.
    Cams can make more power everywhere, but at the small end of the scale. Slightly larger cams will make more power everywhere, after you get to a point, in the case of a 1G I'd say around 215@050" and 8.2mm of lift, you will start to lose bottom end power.
    You can't have your cake and eat it to. WITHOUT spending a fortune that is. SO if you want more power, you need bigger turbo's and bigger cams, especially if you want 300rwkw, and want to sepnd as little as possible. If you spent 10K on the engine, and half of that being on the cyliner head, the other half on a built engine with 9:1 compression, then you could fit your GT30 turbo with a .63 rear housing, make full boost at 3500rpm, and your 300rwkw. But no one does, they want lots of power, little cost, so deal with lag if thats you.
    Ron has had great success with stock 1G's making 400hp at the wheels. I personally have destroyed 6. I find their oil flow to the conrods to be poor, and it definately wasn't tuning that made them expire, it was always conrod bearings 1 and 6. I'd say keep you power goals around 260-270rwkw on stock engine, and your oil changed OFTEN.
    A aftermarket computer is a must for anything over 200-230rwkw, if your trying for more than that, stop kidding yourself and get a 1/2J, if you can't afford a computer and to do it properly, then you can't afford to fix it when it dies from detonation.
    Now to the positives. The 1G with some camshafts can swing to the happy side of 9000rpm without a care. The internal strength is great, you will not break this thing unless you have detonation or the bearings flog out. If you are fitting camshafts, get onto Performance Springs, they have springs off the shelf that I run a 9.7 on, and work a treat, they will work with any camshaft any person on this forum will prb ever play with
    Turbo sizing..... WIth a turbo intake manifold fitted with an XF throttle body, and the factory butterflies removed, you can expect the following output and spool from various turbo's. Please keep in mind this is +/- 200rpm or so, as exhaust manifold design and camshafts play a role.
    2871R garrett or KKR 380 = 230rwkw on 16-18psi.............3500rpm full boost
    3071R garrett or KKR 430 = 250-260rwkw on 19-21psi.......4000rpm full boost
    3076R garrett or KKR480 260-280rwkw on 21-23psi...........4300rpm full boost
    3082R garrett or KKR520 280-300rwkw on 21-23psi ..........4800rpm full boost
    3582R garrett 300-340rwkw on 23-30psi........................... 5300rpm full boost
    T66/TO4Z 350-440rwkw,.......................................... ....... 6000rpm full boost
    Keep in mind that although I list more boost for each stage, just because you fit a bigger turbo doesn't bring MUCH more power, the turbo doesn't just magically push the air in, however each step of larger turbo allows the engine to EFFICIENTLY make more power at each corresponding step by using a larger exaust wheel, and stops power hitting a wall, as each step of turbo prob would around the figures quoted. I have fitted most of the garrett turbo's, 4 different ones to my own engine, and the KKR range is just lining up wheel specs and a bit of an eductaed guess to get you in the ballpark. I have also worked these figures up to GT35 on stock cams, and based on the power figures I have made on a stock engine with stock cams.
    Regards.......................................6BOO ST
  9. #114
    You must spread some Reputation around before giving it to 6BOOST again.
    Great post. I am sure a lot of 1g owners will be reading it over and over again
    QUICKEST 1JZ'S IN OZ
  10. #115
    6boost's article in zoom shocked me when i read the 9000rpm bit, but then i felt nice and warm inside, knowing that theres alot more in these motors,
    and my XF falcoon throttle body is in the mail!!!
  11. #116
    Isn't that a Y bro?
  12. #117
    Quote Originally Posted by SIKTOY
    Haha, if you'd known how much I've spent on the car in total, you'd understand
  13. #118
    Junior Member 1st year Apprentice 16OTU's Avatar
    Yeah i've never had any bearing problems (touch wood), but I also change at 7500-8000 and have the limiter set to 8500. Also my custom sump has a rear pick up so that helps alot I think.
    Also so my turbo is the same spec as a T66 and with Kyle's new manfold makes 27psi by 5500.
    Ron
    [email protected]
    No NOS, No Slicks, No C16.
    442RWHP, More to come!
    My Space & Photo's
  14. #119
    6Boost what would be the best compromise lift and duration wise between say a bit more up top (7200rpm shift point) while trying not too loose bottom end. Also can you get away with the stock valve spring with a little bit bigger grind? Don’t want to pull the head off again.
    I am not chasing peak power just more response and improvement across the board...
  15. #120
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Quote Originally Posted by 6BOOST
    kyle would you have a clue on what exhaust housing to use on the garret 3071R or the 3076R
    top post + rep to you,
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Last Post: 11-10-2014, 01:02 AM
  2. Turbo Heat Shielding
    By MarioM in forum Tech and Conversions
    Last Post: 21-05-2007, 10:18 PM
  3. 3sgte Turbo Upgrade - WRX turbo?
    By medwin46 in forum Tech and Conversions
    Last Post: 25-11-2006, 07:02 PM
