Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 133
Thread: turbo upgrade for 1GGTE
  1. #61
    Default Re: turbo upgrade for 1GGTE
    I recken the 1ggte is a great engine in standard form with the exception of an aftermarket turbo. Since aftermarket parts are a bit hard to get I think if you are SERIOUS about making power id build a 1J/2J with a decent sized turbo. 'Performance' shops actually know what a 1J/2J is. For the same amount of money you will probably make more power.
  2. #62
    oh, ps, IN05NT
    3700 rpm in first for full boost of 12 psi?
    what diff ratio, and what weight.
    and what sort of rpm in 2nd or 3rd?
  3. #63
    Quote Originally Posted by love ke70
    oh, ps, IN05NT
    diff ratio 3.7:1
    weighs...round the 1150 + driver 120
    yep full boost at round the 3700 mark in 1st, then i just get crazy amounts of wheelspin
    2nd probably more round the 3000-3500 then its starts to sway (almost break traction with 225/50/17 big tyre....)
    either way the gt3071r is always on boost after 3500, and by NO MEANS IS IT A LAG MONSTER
    lag monsters are from 5000 onwards
    and im only pushing 12psi, not even 1/2 the capable limit of this turbo
  4. #64
    im still yet to get it running again with NA cams and adjusable cam gears that can change and bring on boost sooner, deopends on the tuner....
  5. #65
    hmm, this sounds better than my fucked rb20 turbo.
    but i ahve a 4.3 ratio.
    4.11 is in the mail...broke the 4.3, fucking bearings exploding...
    mine used to try andlight up first with brand new 225/50r15 with only 9 pound of boost. that was when the turbo used to ramp up hard. now it doesnt see boost til 4grand...stupid housing getting in the way of my turbine
    on the talk of housings, what housings are you running?
    im assuming the small ones?
    i think my original plans or GT3071R will be all good
    no need to play around with getting a 28 housing with a T3 baseplate like my tuner had been speaking off.
    cant wait to get car back on road, i miss the power
    a little lag wont hurt. should be good for fuel economy
  6. #66
    tasmania
    hi guys,
    im very interested in this thread as my turbos have just buggered up..
    so im thinking about going single to..
    my situation is a bit different tho.. i have the 1ggte in a hilux 4wd.. so it pretty heavy and i dont like lag!
    so wat would u suggest? im not after high number.. 180kw maybe 200kw would be nice.. responsive and coming on hard is wat i really want!
    cheers for any help!
    rollsy
  7. #67
    supercharger
    if not the GT28 thats been thrown around would sound the goods to me in your case...
  8. #68
    chasing 180-200kw id leave it stock!
  9. #69
    tasmania
    Quote Originally Posted by Pube
    well my turbos have just blown up.. so i thought i may as well go single now!!
    and im not really chasing any sort of figure! im just giving an idea of what id like.. thats at the wheels tho.. and a 4wd drive line and 32x.11.5x15 tires suck out a few kw!! lol
    rollsy
  10. #70
    yeah dude, but thats running the stockers at 18psi.....they arent going to be reliable for long with that pressure and they are pretty much MAXED out....
    Blake,
    My boost spikes to 1.1bar then drops away to 1.0bar (Say 15psi) I have a Apexi AVC-R which I will hopefully get installed before Dyno day and with that I will be able to hold a steady boost level and sit it right below the boost cut. After that it needs programable management so I can control the timing which it desperatly needs.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  11. #71
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    What you boys recon high-flow gen3 turbos would be worth... I have a set of Blitz Bag hi flow which are 15% bigger then gen 3 turbos wondering if they be capable of breaking 200rwkw. Also anyone know how much a set of cams and cam gears would help overall power... I know drivability will be better improved just curious about the total power output improvement... I know forcefed got 30hp out of his gears alone...
    Just after some opinions to easy my mind while i am working on this
    1G...
  12. #72
    Quote Originally Posted by BLK1g-gte
    I am trying to break the 200rwkw mark on a set of stock Gen 3 Turbo's (Hopefully for Dyno Day) so the BLitz bag turbo's should be capable of it.
  13. #73
    all depends how well set up the motor is and how fresh it is.
    i get a feeling most are fairly clapped out when u get them from the importers, due to the weight they have to lug around.
  14. #74
    Quote Originally Posted by TheToyman75
    unless they're mine
  15. #75
    Quote Originally Posted by JustCallMeOrlando
    unless they're mine
    You can always give them to me
    Last Post: 11-10-2014, 01:02 AM
  2. Turbo Heat Shielding
    By MarioM in forum Tech and Conversions
    Last Post: 21-05-2007, 10:18 PM
  3. 3sgte Turbo Upgrade - WRX turbo?
    By medwin46 in forum Tech and Conversions
    Last Post: 25-11-2006, 07:02 PM
