Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: nitrous tuning 1jz
    Default Re: nitrous tuning 1jz
    can you get a coloured gas to go thru the system and then manually trigger the soleniod?
    Junior Member Grease Monkey Jasper's Avatar
    Trigger it with the engine stopped. (not the fuel solenoid though)
    Wouldn't it then pool in the manifold and when I crank it it could backfire?
    I was told to do the static test which is nuetral to 3000rpm, activate it and if it goes to redline it could be a little lean, if it bogs a bit it is rich. (I have wideband and datalogging anyway) Advised that it can't do any damage to engine at such low TPS setting.
    QUICKEST 1JZ'S IN OZ
    It wouldn't get into the manifold, because the throttle would be shut. The nitrous would slowly dissipate out of the air filter. I wouldn't go starting the engine straight away afterwards...
  1. 1jz to 2jz
  2. 4agte - Tuning tips and experiences wanted
    By Lenso in forum Tech and Conversions
    Last Post: 10-10-2006, 09:45 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
  4. 1jz vs 2jz heads
