Results 61 to 65 of 65
Thread: cressida centre into hilux/hiace housing G series
  1. #61
    Default Re: cressida centre into hilux/hiace housing G series
    thanks chris davey
    we'll soon find out anyway!
    bah its only going behind a 1g anyway, its not like that will brake it, i'll be more concerned when i finally go to a 1j
  2. #62
    All I know is that my diff was welded too close to the splines so I had to chop 10mm off each axle as the welded part was too close. Did that and all is good and that is putting 276rwkw through it on the dyno so far and 230rwkw on the track. All good so far
    QUICKEST 1JZ'S IN OZ
  3. #63
    Forum Sponsor Conversion King
    yep 10mm should be fine but make sure the spline is cut far enough along the axle.
    tip, spread grease on the spline then slide in and remove. if you have enough spline left over towards the bearing end of the axle then trimming is fine.
  4. #64
    thanks guys
    problem solvered
  5. #65
    i put the axles in with some grease on them, shite loads of room to shave off what is needed
    thanks again guys
    By The Witzl in forum FAQ
    Last Post: 19-10-2007, 08:43 PM
  3. IS200 Altezza Type 2 Torson LSD into MA61 IRS F series?
    Last Post: 27-12-2005, 08:53 AM
