Results 46 to 60 of 65
Thread: cressida centre into hilux/hiace housing G series
  1. #46
    Default Re: cressida centre into hilux/hiace housing G series
    shouldnt be a problem, reckon that old zorst could be made compatible with my POS
  2. #47
    You will be able to bolt on the crownwheel and pinion to the hilux centre but the offset is different. You may be able to move everything across to give the correct backlash after you have made new spacers to adjust the backlash and preload . Then you have to hope your axles are the right length to lock into the centre. This is after you have ground down the shaft diameter to fit the smaller hole in the side of the housing. Let us know how you go.
    Jealousy is a curse
  3. #48
    im a bees dick away from putting this in the hardbasket...
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  4. #49
    its a 3mm spacer from memory its no big deal there is another thread on this thats a bit better, i'll try and did it up
  5. #50
    craig...diffs arent my forte...
    what about if i was to say give you the two diffs and some beer and then come back in a few days to collect my diff?
  6. #51
    im flat out mate and besides it really aint that hard dude
    check these out:
    http://www.toymods.net/forums/showthread.php?t=16473
    http://www.toymods.net/forums/showthread.php?p=81788
  7. #52
    rep madmont too he has helped pureinsanity, me and mr1j with our difs
  8. #53
    hmmmm thanks mate...
    ps i already repped him
  9. #54
    Forum Sponsor Conversion King
    1 prob you definately will have is that the irs centre has a groove cut in the female spline to fit the circlip on the irs shafts the live axle centres generally dont have this as the shafts are held in by the backing plate.
    i hope im wrong but i have had some grief in the past
    linden
  10. #55
    Easiest way to go would be to get an open Cressida diff and lock it and put that in.
    Jealousy is a curse
  11. #56
    I think youre right madmont...I wonder if the IRS MX83 housing is the same as Z20/A70
  12. #57
    Quote Originally Posted by madmont
    agreed
  13. #58
    Default HELP!!! my new 5 stud rn85 axles dont fit in my g series diff!
    im digging up this old thread because i have finally got around to getting some 2x4 RN85 5 stud axles to swap over from 6 stud
    i was assured they are a direct swap but on measuring them the axles are about 10mm longer than the 4x4 6 stud one i have in the car now, ln106 i think?
    what do i do now???!
    i wont be able to get a refund, but a store credit will be fine, what axles will swap?
  14. #59
    CHOP 10mm off the axles. They is extra room on the inside of the spline anyway so I don't think it reduces the strength.
    QUICKEST 1JZ'S IN OZ
  15. #60
    just trial fitted the axles then, they have the same splines but they are definately too long
    fkn spewin, more messing around
    By The Witzl in forum FAQ
    Last Post: 19-10-2007, 09:43 PM
  3. IS200 Altezza Type 2 Torson LSD into MA61 IRS F series?
    Last Post: 27-12-2005, 09:53 AM
