Results 31 to 45 of 65
Thread: 200rwkw 4agte???
    Default Re: 200rwkw 4agte???
    Thanx for the input guys. Isnt there a formula somewhere re: cc of inj per kw of power???
    Autronic have one on their site.
    i heard 5cc/min per hp the other day, seems reasonable
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Junior Member 1st year Apprentice WeekendWarrior's Avatar
    new south wales
    i think if u were just to run all the goods they u have listed i think u would be right on the money tell your neibour to add a set of cams like my mate dide he had basically the same combination but had a good set of cams to go with but 850cc injectors and the turbo was a hks 28/35 turboand he pushed out 246rwkw on 22 psi so if thats any help to u buddy.
    ps compression was running at around 8.5:1
    - Project "BILLYGOAT" the ta22 found on the edge of a hill
    BEARCON All your construction needs 67 624580
    THE CELICA SHOP COMING SOON
    Quote Originally Posted by shinybluesteel
    5cc/min per hp for 170hp = 850cc/min injectors, which im certainly not running.
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    you've got a good turbo choice going and that would make the power easily along with some head work and 15-20psi
    mate has a nice setup in his car (FLYNSX on this forum) with a gt2871rs which may be worthwhile checking out or even 30psi 4agte who made 300rwkw
    I have been pruned by old man river!!!!!
    handy calculator for injector selection and rough table of injector <-> power output:
    http://www.megamanual.com/v22manual/minj.htm
    and then scroll down about 2-3 screens.
    Flow rates are primarily in lbs/hr but can easily be converted to cc/min.
  8. #38
    Yeah theoretically you could run a single 850cc/min injector to get your 170hp? Obviously you wouldnt/couldnt do that, so 850/4 = 212.5cc/min.
    Is that what you meant shinyblue?
  9. #39
    isn't that on a per pot basis (at engine power)? (and assuming revs don't cut into injection time)
    170hp = 126kw = 210-220cc injectors?
  10. #40
    S.A
    Quote Originally Posted by allmtr
    My neighbour is looking at getting about 200rwkw out of a turbo 4age. After a bit of searching here and elsewhere I think this might get it done....
    GZE pistons
    430cc injectors (7mgte, I believe bolt in)
    GT28xx turbo
    steam pipe manifold
    3 litre plenum
    Bosch coils
    Microtech ecu
    20ish psi
    Thoughts?????
    This setup will do it no prob mate. You will need a GOOD tune and consider 200rwkw done. If you fall short of this you will need to look for problems somewhere i.e restriction in your I/C somewhere etc etc,as with the current parts list its a shoe in.
    plenty of people have done it including myself
    A couple things.
    Your injectors may or may not limit you. If you have a decent fuel pump and adjustable pressure reg you can up the pressure and you should get away with it.
    I used the 550cc 13b injectors for ages and made 283rwkw with decent pumps and a reg.
    So with the 440cc's i reccon youl be ok.
    Is this a fresh motor ?? As this will make a difference.
    The only other things i had was a slight port clean up ,big port head and big port cams,
  11. #41
    Point taken, posting after christmas party probably wasnt a good idea. But hey, it even made sense when i woke up at 4am
  12. #42
    Yeah we've decided to go with 13b injectors. A good tune won't be a problem as a mate is one of the best in the business
    Motor will be fresh and balanced etc
  13. #43
    I saw on pf what this is going into
    You guys are crazy. Will it beat a starlet?
  14. #44
    ooh be a sport, whats it going into?
  15. #45
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Suzuki Carry...
  1. 4agte Info
    Last Post: 16-03-2007, 08:15 PM
  2. 4agte suzuki sierra!
    By 4agtezook in forum Tech and Conversions
    Last Post: 07-02-2007, 10:48 AM
  3. Wiring 4AGTE into AE86 expert Required
    Last Post: 05-07-2006, 03:01 PM
