Page 20 of 25 FirstFirst ... 101819202122 ... LastLast
Results 286 to 300 of 374
Thread: 1UZ-FE VVTi into IS200
  1. #286
    Default Re: 1UZ-FE VVTi into IS200
    4-1 is twice as long primary as 4-2-1 yah?
    where is mos?
  2. #287
    Penrith BC
    no not relly. primary length is a fixed number - then it becomes a packaging issue. 4-2-1 is an attempt to reduce interference from whacko firing orders the v8 gets per bank in a 4-1 collector (the poor mans 180deg header) - not sure of the real word benefit of 4-2-1 vs 4-1, its certainly debatable
    perhaps my pic above is a misleading angle? theyre not THAT long. 33-35" overall primary length. some swear by the magic number 32", i calculated a bit longer, rms' engine is longer still. i think the 33-35" range is about spot on
    mos? sleeping i suspect
    ../delete/ban
    tech moderator
  3. #288
    Where: Rockhampton.
    Clutch ordered: no.
    Those Cobra headers are what both you and I should have (and maybe the rest of the car too).
    Mos.
  4. #289
    It's going to be hot enough under the floor without pointing those things straight through the firewall. Ready to wire this weekend?
    Friends
  5. #290
    Need GT40 + flat plane crank and 180deg headers
  6. #291
    Quote Originally Posted by YelloRolla
    Mmmmmm GT40 !
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  7. #292
    So um Mos....what do you reckon are the chances of you wanting to do another engine conversion.. possibly a non vvti with any compatiable manual box (maybe a R154?) into an auto is200? Any chance or are you already running in the other direction?
  8. #293
    Forum Sponsor Conversion King
    hehehe, mos wont even finish is own car off let alone doing another for somebody else.
    its not an overly difficult job but it is very fiddly and i doubt it could be done for under 10k if done properly.
    linden
  9. #294
    it's only fiddly if you do it properly
  10. #295
    ^^^^ is there another way that i don't know about?
  11. #296
    bodgy.. fencing wire instead of cable ties... garden hose instead of EFI spec
  12. #297
    Yeah, Nah.
    Mos.
  13. #298
    Not deburring every hole that was also drilled to a cad drawn template to matching chamfer angles.
    just jamming the ecu under the dash behind the original so it looks std.
    Friends
  14. #299
    Quote Originally Posted by YellowIS
    I'm running the other way, but just out of curiosity, what would you expect to spend? I'd need a lot of persuading...
    Mos.
  15. #300
    YellowIS,
    Mos has enough unfinished wiring jobs to keep him busy well into retirement
    Last Post: 29-10-2021, 09:49 AM
