Page 15 of 25 FirstFirst ... 51314151617 ... LastLast
Results 211 to 225 of 374
Thread: 1UZ-FE VVTi into IS200
  1. #211
    Junior Member Domestic Engineer ZZE92's Avatar
    Default Re: 1UZ-FE VVTi into IS200
    "what do you mean you don't want a hole there????"
    Lol.. looks like I missed out on the fun after I left - Didn't think he was going to let you anywhere NEAR any powertools
    Paul.
    the snatch has been through hell and back and is still kicking!
  2. #212
    Quote Originally Posted by ZZE92
    I wasn't worried about the strut tower - it's the bit that came before that photo that was the real worry! (the guard )
    Mos.
  3. #213
    Everyone knows strut towers are stronger when pop riveted
    Friends
  4. #214
    Forum Sponsor Conversion King
    Quote Originally Posted by clubagreenie
    especially when you drill the spotwelds out first as it gives the rivet a stronger bite.
  5. #215
    Then we weld the rivets...
    Friends
  6. #216
    Montrose
    Aluminium rivets.
  7. #217
    Penrith BC
    Quote Originally Posted by Mos
    Ed, wanna get two?
    yes
    so am i buying, can do asap, just let me know
    ../delete/ban
    tech moderator
  8. #218
    Yes please
  9. #219
    Penrith BC
    done and dusted
    ../delete/ban
    tech moderator
  10. #220
    Default Dyno Graphs Re: 1UZ-FE VVTi into IS200
    Dyno graph 204.5 RWKW at ~6900rpm at ~12.8 AFR with a 7200 rev limit.
    Dyno graph 189.8 RWKW at ~12.2 AFR (after changing the coolant temp sensor type - don't ask).
    Mos.
  11. #221
    so have you finished the wiring yet, those 2 wires you have left to hookup to get the vvti working must be a real pita to twist&tape.
    is it covered in convoluted tube yet or still looking nasty.
    [mos' emo answer would be "no i havnt had time yet, im too busy scratching my balls (wait thats rod) and thinking of the hardest possible way to do it".]
  12. #222
    No, the VVTi cam angle sensors remain unconnected.
    Yep, sure, quarity twist and tape
    Still "wiring by cable tie". On the plus side, the ECU box lid has been located
    Mos' emo answer is "no I haven't had time yet, I'm too busy catching up on a month of foregone socialising"
    I'm still trying to figure out how to fit the SM4 into the IS200 ECU box without cutting it up...
    Mos.
  13. #223
    I had to cut up the SM2 to fit in the IS200 ECU box. Made a new aluminium case to hold both ECU's together with about 5mm between them.
    Graham D
    Lexus RX350 (no mods yet !!!)
    Lexus IS200 / 2.5GT-T (1JZGTE VVTi + Getrag 6 Speed)
    Lexus IS200 (wife's car and no mods allowed !!!)
    Suzuki GSX750-F
  14. #224
    Yep yep, I remember seeing the photos ... Unfortunately the SM4 is taller than the SM2 (a bunch of daughter board) and I don't think I'd actually be able to get both the SM4 and the 1G ECU both together inside the white, moisture free tray...
    I'm trying to fit them both in the black enclosure - I'm pretty sure I can seal the SM4, so it shouldn't be too much of a problem having it outside the white tray.
    Mos.
  15. #225
    Is it just a neatness thing? Whats wrong with having the SM4 in the cabin?
    Last Post: 29-10-2021, 09:49 AM
