Page 5 of 25 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 374
Thread: 1UZ-FE VVTi into IS200
  1. #61
    Default Re: 1UZ-FE VVTi into IS200
    Quote Originally Posted by BlackSupra
    It's just waiting to rape something.
    Its deffinatly going to F#ck BMW owners
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  2. #62
    Junior Member 1st year Apprentice beerbaron's Avatar
    Jan 2007
    sa
    thats crazy
    when your done , let us know when I can give your my car to have that transplant
  3. #63
    That's it, I've given up, the 1G is back in... Justen - when are coming over?
    ...just kidding (about giving up).
    Thank you all for the kind words (of Bavarian fornification...).
    Some updates. A NZ bellhousing was tried (thanks Ed) with a W58 (thanks Ed).
    The bellhousing itself looks quite nice. The tip of the input shaft protrudes into the crankshaft (bottom image) just the right amount, and in general everything lines up.
    The bellhousing fits the engine reasonably well, although the holes for the dowels are not quite right - about 0.5-1.0mm out. The factory bolts, while all lining up quite well, would require a little bit of clearancing to allow some sort of tool (socket or ring spanner) to be used to actually tighten them (the lack of bolts in the image is mainly due to laziness of having to do them up by hand as virtually none of the recesses fit a socket).
    The gearbox interface is somewhat similar. Recesses are not quite large enough to fit a socket and, while the dowels line up perfectly, the bolt holes are just that little bit off that you can't start the thread with confidence.
    Options are either to mill out the bellhousing, grind down the socket, or use hex bolts.
    Installed in an IS200 on the custom mounts, the above combo places the JZA80 shifter some 10mm rearward of the centreline of the auto shifter.
    Manual pedal box has arrived (Thanks Glenn) but not installed yet.
    Exhaust is done but no photos at the moment.
    Mos.
  4. #64
    Quote Originally Posted by beerbaron
    thats crazy
    Mr Baron, I'd highly recommend a 1JZ
    Mos.
  5. #65
    so thats what eds parts look like actually assembled
    Friends
  6. #66
    Luckily the JZ bellhousing was the dirtiest part
    Mos.
  7. #67
    So Mos, some questions.
    Autronic? Commandeered Ed's bellhousing? In? Running? Working? Skids and pictures thereof or are you really going to make us wait?
  8. #68
    Just need to find a way to "borrow" Ed's flywheel, then I'm set
    It was in already, now it's out. Need to collect remainder of manual parts, then pull the car back apart and pillage (it only took less than two evenings to put it back together - needed a break from driving the "hire" car).
    Factory ECU still not completely ruled out.
    Mos.
  9. #69
    Quote Originally Posted by Mos
    Get another made by Race Alloy Components dude.
  10. #70
    Quote Originally Posted by gianttomato
    Way too expensive. (double what Ed paid).
    Mos.
  11. #71
    i'm just posting to repeat what just about everyone else here has said; this is a fecking awesome project, with some fecking awesome workmanship behind it from all involved.....
    .... except Rod.
  12. #72
    The last time I tried to buy some cap head screws in M12 x 1.25, they were a bit hard to come by! Maybe some factory Toyota cap screws sourced from another part could do it???? OR maybe I am dreaming and they're now readily available??
  13. #73
    Specialty Fastners here in ACT has them no probs. Got mine in Zinc i believe
    I have a box of 10 here. I got them thru Metfasteners in Chifley Drive, Preston Took a day to get in.
  15. #75
    Penrith BC
    boltmaster in nth paramatta has them - just bought a bundle for the brembo caliper brackets
    ../delete/ban
    tech moderator
    Last Post: 29-10-2021, 09:49 AM
