Results 61 to 69 of 69
Thread: Compression test results
  1. #61
    Default Re: Compression test results
    [QUOTE=dale30]
    Ok, The Carbies need to be running at 2.8 - 2.3 PSI !
    Buy an inline guage if you want but cheap guages can give poor results so I recommned seeing if your "mechanic" has a good quality fuel pressure guage that can accuratly measure carby level fuel pressures. (Ideally you want a gauge that only reads to about 10psi so you get a really accurate reading)
    This is true but a cheap guage will still be within a pound or two and tell if its a high or low pressure pump.
    Dale,
    The pierburg is a low presure pump if thats what it is and I lean heaviliy towards it being one ! At the end of the day tho Jill should not need to buy a tool that she will only need to use once or twice. The mechanic who did the recent work should be happy to check it as a gesture of good will if not out of guilt.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  2. #62
    Junior Member Grease Monkey minxgirl's Avatar
    Its been said a few time but the very next thing you need to do is check your fuel pressure just before it enters the carby. Buy an inline guage if you want but cheap guages can give poor results so I recommned seeing if your "mechanic" has a good quality fuel pressure guage that can accuratly measure carby level fuel pressures. (Ideally you want a gauge that only reads to about 10psi so you get a really accurate reading)
    If the pump is running more then that it is almost deffinatly your problem.
    DO NOT ditch the pierburg pump ! it is perfect for the job ! What you do need tho is an inline fuel pressure regulator. I will check the 2TG storage lockers at my mums. I am sure I have one I can send you. Fit it inline and set the fuel pressure
    If it would me I would capitalise on your being a female and call your mechanic, ask what fuel pressure your car has been tuned at. Since they diagnosed the problem and then charged you for a rebuild and tune they should know When they dont know and you can show them they stuffed up is when your boyfriend actually does become useful by gently suggesting the fit the reg I can send you. Set your base pressure and retune your carbies at no charge.
    Say the word and I will copy the Solex Mikuni set up, tuning and rebuild pages in the workshop manual.
    THAT is diabolical *LOL*
  3. #63
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    [QUOTE=TheToyman75]
    Quote Originally Posted by dale30
    Dale,
    If it is a pierburg low pressure...We are back to the drawing board. Im hoping its a VL commo pump.
    Totally aggree with you about the mechanic but damm it would be nice for a girl to go back to the experts and say...hey this is no good because.
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
  4. #64
    Car is at the mechanics and they gave me a loan car which pacified me slightly *LOL* Will update when theres something to update now I guess
  5. #65
    wat loan car did you get?
    hope your gonna thrash the bejesus out of it
  6. #66
    Hoppers Crossing
    good luck mate hopefully all goes well
  7. #67
    Keep us informed Jill.
    Rod.
  8. #68
    Car is at the mechanics - hopefully they wont take eons this time in sorting it out - the guy at the desk understood exactly the situation when I explained it to him (about the fuel pump etc) and the guy who rebuilt my carbs is "no longer with them" apparently
    Yeah and my boyfriend looked rather sheepish as the guy drew a diagram and explained back to me what I said to him and I said "thank you, there you are Tim thats what I was trying to say but you couldnt understand - now run along to all those people who you chatted to about me being wrong and the theory being impossible etc etc etc" HAHAHA
    Guy at the desk agreed the mechanics should have realised - mechanics he spoke to agreed it sounds very likely - now just gotta wait till they get onto it ...
    Got an old Magna loaner with an overheating issue to drive around in until they fix my car - I dont care - saves me taxi fares
    PS. November 16th and we got SNOW here today! Armidale NSW
  9. #69
    Sounds promising Jill.
    Fingers crossed they will get it right for you this time. Make sure they know you can supply the extract from the workshop manual re the carbs in case they need it. It could save you allot of time and is easily mailed.
  1. 1ggte COMPRESSION TEST....readings.....SORTED!, cheers
    Last Post: 23-08-2006, 11:12 AM
  2. What do these compression test resaults mean...
    By doobs in forum Tech and Conversions
    Last Post: 13-06-2006, 09:41 AM
  3. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 06:06 PM
  4. Dyno Day 12 - results thus far...
    Last Post: 28-01-2006, 01:35 PM
