Can you list what you are getting for each cylinder. As long as they are all pretty close to each other it should be fine.
hey guiys doing a compression test on the mighty 1g.....i think ive got a suspect blown HG![]()
what should the readings be?
round 150?
cheers, blake
Hello.
If it's running, dont dick around with a compression test to check for a BHG, go to a radiator place or workshop and get a Teekay test done. Cost me nothing.
just did the test then,
its reading 150kpa on all cylinders.....
cant find specs for a 1ggte in the books, but cressidas...7m's between 130-160kpa
so i think im ok in the compression dept,
oils not milky, coolant is still clean.......
what brings this up is that my rad was about 1ltr -1.5ltrs low the other day, and my temperature gauge sender sits in the top hose.....and i doubt it was sending the right temp reading....
now to pressure test the rad.....
What reading was the temp gauge saying?
temo sits on about 1/3 of the gauge, but its the factory 223 gauges its hooked up to,.....
i'll fit my new water temp gauge tonight....![]()
blake![]()
WELL HEY, THE RAD WAS 1/2 EMPTY......,
but im a bumbass!, i run a over flow bottle for the coolant...like most....
but me, an idiot, was running a NON recovery radiator cap, so all that was hapenning was my overflow bottle was filling but not recovering,![]()
$8 and a REcovery cap fitted, all good!![]()
cheers guys for the help!![]()
blake![]()
Hahaha, thats even worse than my special viscous fan![]()
