Results 46 to 48 of 48
Thread: external wastegate....which one??? HELP NEEDED!
  1. #46
    Default Re: external wastegate....which one??? HELP NEEDED!
    guys i ended up going with a 38mm genuine tial, picked it up for $300 delivered on good old e-bomb
    also since we last yabbered on about size of wastegates i found thi to be really useful
    http://www.turbosmart.com.au/index.php?s=faq
    in particular, take note under the wasgate info that bigger isn't always better
    craig
  2. #47
    Worlds Fastest 1G Backyard Mechanic
    The biggest gate you can afford or that is sensible is the best, regardless of what you read. A bigger gate helps to bypass more and hence hp robbing back pressure, I Have seen as much as 25rwhp gain on the same boost and engine by simply going from a 38mm gate to a 45mm gate. And I've seen about 10 38mm gates on those cheap stainless manifolds on RB's and 2j's control boost till about 5000rpm, then just creep higher and higher, the best yet was an SR that held 14psi till 6000rpm, then creeped to 35psi by 7500, no bleed, no control, straight off the cooler plumbing. I'll be investing in one of the new TIAL 60mm gates when they are released here in aus
    6BOOST
  3. #48
    n.s.w
    i'm looking for a external gate for my gte i'm using a GT28 & making my own manifold maybe later down the track i'll upgrade to a gt30 or something but anyway i'm still confused on what size to go to.
  1. Swapping wastegate actuators...
    By mullett in forum Tech and Conversions
    Last Post: 28-07-2006, 10:21 AM
  2. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 11:15 AM
  3. Internal or External Wastgate?
    By toddw in forum Tech and Conversions
    Last Post: 24-12-2005, 07:30 PM
