Results 46 to 60 of 62
Thread: MX73 strut into AE86
  1. #46
    Default Re: MX73 strut into AE86
    bout 140mm .... caliper mount is integrated into the dust shield.
    Black Betty >HERE!<
    (\__/)
  2. #47
    Victoria, Mt Macedon
    Quote Originally Posted by slide86
    what is the distance of the calliper bolt holes on a ra40 strut? same as 60?
    No, RA40 caliper mount holes are further apart than RA60.
    Also RA40 mounts to the rear of the strut and onto a backing plate. RA60 mounts in front of the strut and has mount cast onto strut leg.
    Hen
  3. #48
    south australia
    cheers for that. there goes that idea
  4. #49
    I put RA60 brakes on an RA23 strut (same as RA40) a few years back. You need to fabricate a new backing plate but it's pretty simple. Pics here:
    http://www.norbie.net/BrakeMods.htm
  5. #50
    That's exactly what I was planning on doing Norbie. By any chance do you recall how thick the mounting plate needed to be?
    Hen
  6. #51
    Hen do AE86 and RA40 share the same strut insert?
  7. #52
    From memory the caliper bolts to the back of the plate so the thickness doesn't matter WRT caliper offset, just make sure it's nice and strong. I think I used 5mm plate but I really can't remember, I did this a long time ago.
    I might add the braking performance is excellent in an RA23 and would be better again in a lighter AE86. You really wouldn't need anything bigger than this unless you were building a dedicated circuit racer. Also you can use 14" wheels with these brakes which is a bonus for some!
  8. #53
    Quote Originally Posted by minorobsession
    Not sure, I'll let you know when I check. Or just look up some shock inserts for each and check the body diameter.
    Norbie, the claiper has the threaded holes in it, so it goes in front of the adaptor. However your pictures give a good idea of the thickness to use.
    Hen
  9. #54
    Looks like the shock size is ok from the dimension in a catalogue I was looking at even thought the part nos are the same.
    Seems that RCA for AE86, RA40 and AE86 have the same whiteline part numbers.
    Why would I not just use RA60 strut and brakes? Unless there is another reason that It won't work. The only thing left to find out is the KPI. I would be happy with 0 degrees of camber or there abouts.
  10. #55
    south australia
    they wont bolt onto the steering arm. just like my st141 ones wont. thats what i was told anyways
  11. #56
    Whiteline RCA part number for RA40 RA60 and AE86 is the same so they should bolt up to the steering arms slide86.
    Looks like I need to visit pick and payless again and do some research
  12. #57
    south australia
    hmm interesting. ill check it out too.
  13. #58
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    whiteline is wrong
    no if's, no buts
    wrong
    RA60 is definately wider between the holes.
    RA40 has same pattern as AE86 tho.
    Dan
  14. #59
    south australia
    yeah thats what i thought
  15. #60
    Doh I thought I was onto something
  1. AE86 Strut bolt spacing
    Last Post: 10-09-2006, 04:33 PM
  2. Strut Brace Stock AE86
    By grey_nomad in forum Tech and Conversions
    Last Post: 21-07-2006, 11:58 AM
