Did some research today:
MX73 rackends/tie rod end are much the same lenght as the AE86
The gotya is the ball joint on the MX73 rackend is shorter than the AE86 so it would shorten the distance between the two rackend ball joints by about 10mm thus introducing bump steer.But it would work if you were not too fussy.
The radius arm does not fit the MX73 LCA due to the fact that the bolt spacing is wider. You could file the holes if
This is what I think I will look at tomorrow:
AE86 LCA
MX73 Lower ball joint
MX73 Steering arms
AE86 Rack ends
MX73 Tie rod ends
Make an adapter from hex bar that screws into the MX73 Tie rod end and onto the AE86 rack end.
Can you safely press out the lower ball joints from the LCA without wrecking them?
MX73 ball joints dont fit into AE86 lower control arms. Are there any ball joints that fit into an AE86 control arm with a larger taper?
