fair enough as I won't be doing many if any track days these should be perfect. thanks guys
MS51Crown Coupe,
What you will notice with the stone guard on the ra28's, it covers the whole disk, so air flow seems impossible to cool the disk.
But if you get the XT130 cover, it has a air pick up area. So a section faces the other way (inwards).
I tryed to buy the set from pick/payless but they wanted $30 for them.![]()
my previous RA28, R.I.P is here.
http://forums.toymods.org.au/index.p...t=0#msg_651396
Current build here.http://www.toymods.net/forums/showthread.php?t=33512
FJ40 landcruiser
HJ47 landcruiser
FJ55 Landcruiser
MS65 Crown
Hi, I am after some specific struts, which I am not sure if they exist, but here is hoping they do. Basically I am running RA60 struts with gx71 hubs and brakes for248x 22mm vented discs. (which for the record are absolutly fantastic with a decent compound under race conditions, current using wilwood polymatrix E compound). However in looking for the next level I want to go to wilwood 4 pots. so.. The struts have integral caliper mounts which just make things hard work for mounting the wilwoods.
The questions.
Is there a struts with 90mm lower spacer, large wheel bearing size, same kingpin angle and REMOVABLE caliper mounting plates?
Other wise its get out the grinder and use the backing plate holes to hold a plate on, or weld new mount points on.
Logan.
Why do hou have to stay 90mm spacing? You should be able to get similar length steering arms in an 85mm spacing which will open up your options. Sheepers mods to his RA28 struts looks close to what you want, stub axe is also the same.
http://www.toymods.org.au/forums/sho...&postcount=432
Callum
Hmmm, all the 90mm struts I've seen are built in caliper mounts. Grinder might be your best option.
Callum
Yeah, RA28 struts are about as close as youll get. This is what i have done with mine:
^^that looks familiar
it looks identical to what i did for my RA28.
great minds ay........
your pal,
sheepers.
69 MS51 crown coupe. http://www.toymods.org.au/forums/sho...980#post835980
RA23 celica with 1JZ-GTE. http://www.toymods.org.au/forums/sho...sheepers+jza23
76 RA28 celica 1UZ, http://www.toymods.org.au/forums/showthread.php?t=12299
Heh, ill do a write up on that eventually. RX7 caliper, 8mm caliper bridge and Mazda MPV discs
hi,
i was looking to find out what master cylinder would work well with this conversion on an ra40? i am unsure which size my booster is.
also where in north suburbs of adelaide can machine down my rotors? A few places have already told me they wont do it because it is unsafe.
thanks for your help
Cheers Shea
hey have you tried kents brake on port road.. they will do it... or a enginer shop...
cheers sam
Hi all,
I have a question with regards to the strut/caliper setup.
I have a pair of ST141 struts and the distance between the dust seal surface and the centre of the caliper hole is 60mm.
Could someone be kind enough to tell me the distance for the RT132 / XT130
Thanks
sorry i should have put a picture
