Page 32 of 68 FirstFirst ... 22303132333442 ... LastLast
Results 466 to 480 of 1006
  1. #466
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Default Re: [Guide] Corona/Peugot/Hilux Conversion with Height Adjustable Coilovers [56k DIAF]
    It's your decision and your conscious that you have to live with as a result of that. I just hope they don't fail like Linden mentions above and you kill yourself or worse still, take some other innocents with you. Toyota (Sumitomo really) makes its calipers that thick for a reason, and no, its not to make car modders upset with the weight of the things, its so they last for donkey's years and don't fail. You don't seem like the person who would take shortcuts on something as important as brakes, especially with the trouble you are going to with modifying your car. Why take shortcuts? Money? Do you really want to do this just because of the new paint on them? Consider getting the correct calipers in the first place...
    RA23
    1G-GZE
  2. #467
    Having got a pair of these, i can assure everyone that the section she'd need to machine is not the bridge where the fluid gallery runs. It's the cast sections that form the sides of the channel that the disk runs inside.
    However, i think you'd find that the the thickness of two new pads plus the wider disk wont fit between the pistons unless you pu a spacer in the bridge. Cost of spacer is probably more than locating another pair of these from the wreckers and putting a new kit in.
  3. #468
    i was just going to say that the pads woulnt fit even if you machined it out.....
    there only 150-200 a pair, and sell these ones off.....
    blake
  4. #469
    being an engineer i would have thought you would have more sense than doing something like that but then again ive met some dodgy engineers b4 so i suppose go with whatever suits your needs.
    Thanks for the compliment.
    Being an engineer and having already stripped the calipers down and rebuild them, I know what I am looking at, the part that I am talking about is part of the casting shape of the outside of the caliper and there is no fluid gallery behind it, nor is it near the piston bores.
    It also doesnt have very much of a structural bearing, its no where near the mounting point for the strut, or the area where any forces exerted on the pads could transfer into the caliper housing. Its just part of the casting pattern from when they were made, really doesnt serve much purpose.
    To give you an idea, refer circle on right of pic, this is the bit im talking about. You would only need to mill down that front bit, nothing past the groove you can see behind it. You would only need to mill down ~3mm off each caliper half. Its not like im machining half of the caliper away to lighten it up or anything.
    If I could be bothered or had the time, I could probably knock up a 3D model of a caliper, import it into Ansys and do a FEA stress analysis on it to prove my point.... but there's probably not much to gain by proving myself to people on here. Im not dumb, I do think of safety as I know what cars can do to people, ive seen it first hand. At least I have the experience and knowledge to back it up. Not everyone has that and I can see why everyone does shy away from a slight modification on a factory part, but I dont see what the fuss is all about. I wouldnt do it if I wasnt confident.
    Charles, you make a good point about the pads may not fit in there though, didnt get that far as well the calipers didnt fit to start... will inspect with my calipers again when I have a chance in between uni assignments and trying to get my bloody 4B back on the road
    Toyota Car Club (Qld)
  5. #470
    Just pop a pad in there static and see where the surface of the pad rests compared to the casting. Im 99% sure that it will be close to if not even with the casting.
    To make those solid caliper castings they just re-set the base of the cast so it ends up being 5-6mm smaller. Hence you would have to grind down your pads to get them to fit post milling the caliper.
  6. #471
    I think there is a set of these calipers at pick n payless in NSW blacktown if someone was looking for some.
  7. #472
    I like Stuff Backyard Mechanic mikie's Avatar
    noletek ra23 adjustable strut tops(cambe and caster adjustable), under $500, 'geelong clutch and brake' 52227411.
    just a bit of useless knowledge.
    got a clutch clave and asked. coilover kits $200 plus. (sleve, locking rings, top spring seat and spanners)
    im drunk,
    cheer mike.
  8. #473
    Forum Sponsor Conversion King
    Quote Originally Posted by mikie
    im drunk,
    cheer mike.
    whilst the noltec ones do fit they only have an 8mm bolt which slops around in the body,
    you would be better off using tein or other jap brand ones as they fit better and use quality bearings in them.
    linden
    EDIT: s13 ones fit.
  9. #474
    WA (Perth)
    Tien do adjustable strut tops for RA23/28's? Do you have the part number for that? Thanks.
    RA23
    1G-GZE
  10. #475
    linden
    EDIT: s13 ones fit.
    do they need any mods to fit?.....seems like your the bloke on susp knowhow on here
  11. #476
    No mods... S13 Silvia have the exact same strut bolt spacing as the early Celicas...
    ([][][]II--LT--II[][][])
  12. #477
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    I thought the s13 needed some slight modding, ie. 1-2mm bigger holes
    sam.
  13. #478
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    Yes S13 just needs slight enlarging of the 3 holes... but everything else bolts right up onto the normal strut.
    Brendon
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
  14. #479
    hrmmm varying stories on fitment.
    either way their a walk in the park for Celicas
    Black Betty >HERE!<
    (\__/)
  15. #480
    what brands are people here using for their coilover sleaves. and what prices are you paying. anyone used the ones found on import bitz?
    cheers mike
