Page 6 of 21 FirstFirst ... 4567816 ... LastLast
Results 76 to 90 of 309
Thread: The old "volvo diff into celica conversion"
  1. #76
    Default Re: The old "volvo diff into celica conversion"
    Well there are plenty of vl commodores getting around on stock diffs and making retarded power and 10 second passes... and quciker even, i think the matouk racing cars have vl turbo diffs and are both going 8-9seconds??? not 100% though...
    So the commodore diff is a indestructible diff... Well, atleast very f*cken tough...
    Jase
    JZA023
  2. #77
    Junior Member Backyard Mechanic TA22 1MZ's Avatar
    I recently acquired a Lockright centre for my Volvo diff. I asked for a cheaper postage option and it only worked out to be $45 and took about 3 weeks. I got it when the exchange rate was heaps better, but even now, works out cheap compared to buying locally.
    Here is the guy selling them on ebay. If you want one, just ask him to use a cheaper postage method and he'll help you out.
    http://cgi.ebay.com/ebaymotors/ws/eB...m=380065081323
  3. #78
    who did you guys use to re stud your axles and how much did it cost, think I am getting a bum steer with Craft and Diff Technics.
  4. #79
    hey mate
    i had the whole diff done - including studs for $500. the diff was bare and i had the mounts cut off the celica diff ready to go.
    the next time i did studs i think it was $120 but cant remember if that was per side or in total..... that was welded, machind and re-studded.
    Stew
  5. #80
    was that a place up in newy stew? got their details for reference?
  6. #81
    yeah mate, up here in newy - promac engineering.
    I have had a few things done there - door hinges re-pinned etc and have been good.
    problem is there is a few tools there and a good guy. i go straight to chris when i go.
    Dunno what they charge now - that was a cash price a couple years ago, but have always found their pricing good for machining/welding jobs i couldn't do.
    Stew
  7. #82
    Mates about to send a ovlov to the scrap, anyone want the diff from it? Dont know anything about it, but its an 80s style wagon
    Jase
    JZA023
  8. #83
    I'll grab it if not too far away.
    where is it located?
  9. #84
    Sussex
    Hi all
    I've been offered a P1216409 - 3.73 - 1041K axle from a Volvo 960 - with an LSD. I think this is too new to fit though. I've read this thread numerous times and people only mention the 1031 and 1030 axle. Would the Volvo 960 axle fit, and what issues would I have above fitting the axle from the 240/740?
    Cheers in advance
    Stephen
  10. #85
    Jase
    Yeah id be interested also if falls through
    -Just Alloy Radiators-
    www.alloyradiators.com.au
  11. #86
    Quote Originally Posted by Rizlam
    Hi all
    Cheers in advance
    Stephen
    the later model diff are wider then the earlier 240's.....the 740 and 960s are 100mm wider.....
  12. #87
    Sussex
    Thanks for that. Other than the width though, what other barriers exist to fitting these? And is the width difference big enough that the front axle would need to be pushed out further also?
  13. #88
    Mate if the diff has been offered to you for free then take it even if it is just for the LSD as you should be able to use it in a 240 diff.
  14. #89
    Sussex
    No, not free at all - the guy will want £150UKP ($300 AUSD?) at least
  15. #90
    Tell him he's dreaming and go and find yourself a 240 diff as it will be the better length.
    If you are looking at shortening the 1410mm volvo diff you can use the longer axles from the 1510mm 740/940 diff as these work out great as they can be resplined so that you can shorten the diff from 0 - whatever mm.
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  2. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  3. F-series diff knocking
    By Draven in forum Tech and Conversions
    Last Post: 14-12-2005, 03:04 PM
  4. Toyota Model Codes Explained
    By wagonist in forum FAQ
    Last Post: 14-10-2005, 10:47 PM
