Page 8 of 21 FirstFirst ... 67891018 ... LastLast
Results 106 to 120 of 309
Thread: The old "volvo diff into celica conversion"
  1. #106
    Default Re: The old "volvo diff into celica conversion"
    ok... so basically any locker is going to be aids for track days, but good for drags.
    Whereas a torsen will be good for both?
  2. #107
    Ok I should update.... i had another chat to craft diffs this morning.
    $450 to swap the mounts and straighten the housing.
    $150/side to restud to 4x114.3
    $80/side for bearings
    $990 for trutrac centre
    = $1900
    That is painful.
  3. #108
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    Yeah, torsen or friction is what you want for an all purpose diff.
    Motorkhana favors the friction type a bit, since torsens may still occasionally spin the inner wheel if you unload it almost completely around tight hairpins. Friction type LSDs have more preload to work around that. The tradeoff is clutches that wear out.
    $1900 may be painful but that would be doing it right the first time - cheaper in the long run.
    '73 TA12 Carina - pushrod power project
    '77 TA14 Carina - 1GGTE swap in the works
    '77 TA23 Celica - 1UZ swap abandoned, selling shell to someone with JZ plans...
  4. #109
    im looking at buying the trutrac from the USA directly now - exchange rate is back above 0.80, so its going to hurt a LOT less than $990 from the local guys!
  5. #110
    TT 912A588 is the part number for the rear trutrac unit. The front one is TT 912A585. Look for the right one but both will work.
  6. #111
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    hhhhmmmm now i am also thinking of doing the diff now.... maybe not the centre as the celica will remain stock motor for some time, but the rest... and since i know the exact wheels i want, then converting to 4x114.3 is no issue for me...
    time to look for a diff....
  7. #112
    Junior Member Backyard Mechanic TA22 1MZ's Avatar
    I have a Volvo diff already converted for our Celica's including the stud pattern change to 4x114.3
    I am currently converting a RN20 Hilux diff to use because I have gone to 5x114.3 with my new wheels
    Once this is done the Volvo will be up for sale ready to bolt in. You will only need to look at the handbrake cables and adapting them to fit. I do have someone interested already, but if it falls thru, I will let you guys know.
  8. #113
    I just contacted Drive Train Specialists in Michigan, and its US$450 for the trutrac centre to suit the Volvo Dana 30 rear end, with gear ratios from 3.73:1 and numerically higher (shorter ratio).
    Fedex through my work is AU$195... so thats AU$760 landed on a 0.80 exchange rate.
    Im now looking into costs for consolidated air freight for multiple units, and might consider a group buy, if i can find the Trutrac part numbers for Toyota F series and G series centres.
  9. #114
    Quote Originally Posted by TA22 1MZ
    mate i would be interested, what is the sale cost?
  10. #115
    I'll check out my guy in the US Karl
    For G series, I can get Detoit True Trac centres for $490 AU, Detroit Lockers for $610 AU and he cando full spools also.
    Freight is $130 AU on each centre.
    I would imagine the Dana 30 centres would be the same price as the G series, but I will enquire. So for a Detroit True Trac you'd be looking at $620 AU landed and for a Detroit Locker $750 landed
  11. #116
    Quote Originally Posted by fade-e
    $1,000 for the whole lot ready to bolt in.
    There is 1 person in line already though
  12. #117
    thanks Jack.... the prices im looking at for Toyota G series are similar to yours (US$389). The Dana 30 centres are a bit more expensive at US$450. Check with your guy as well just to make sure
    If i get a few units together i can probably get freight below AU$100 per centre shipped by AIR thanks to the awesome import freight rates we have at work (importing 10 containers a week gets you phenominal rates).
    Just some food for thought
  13. #118
    No worries Karl, I'll go with you then mate once. I'll still confirm that the Dana 30's are at that price with my contact.
    The centres you are enquiring about, are they Detroit branded? If not, what brand are they?
  14. #119
    I'd be interested in a centre too...
    Stew
  15. #120
    We have ourself a group buy then
    Run it by the mods Karl and see if there is any interest outside this thread.
    The more centres we can get, the better price it will be. Get them all delivered to you and leave it up to the buyers to pick them up or sort couriers to grab them.
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  2. changing the gear ratio's in hilux diff.
  3. F-series diff knocking
    By Draven in forum Tech and Conversions
    Last Post: 14-12-2005, 02:04 PM
  4. Toyota Model Codes Explained
    By wagonist in forum FAQ
    Last Post: 14-10-2005, 09:47 PM
