Must build monster engine.
I've heard rumours that Damien is coming, but I haven't heard him say it himself...Originally Posted by Alchemist
2JZ No shit?
nah, damien says he wants to come - last dyno day where he stands a chance for 4.0L NA horsepower trophy![]()
../delete/ban
tech moderator
Rod, Port pairing was kept as per factory ie 1-2-3 and 4-5-6. Primary was mandrel bent 1 1/2" into 2" secondary then 2 1/4" at the collecter thru 4" high flow cat and 2 1/4" exhaust with resonator and straight thru box. Will get back to you with lengths.Originally Posted by TheToyman75
Do you have the same steering rack limitations in the crown as the MA61?
i eagerly await primary/secondary lengths! I would guess 150rwkw would be the rough limit of an unopened motor.
Wayne,
Mate my Stearing box is deffinatly a PITA. I had to use a 1JZ-GE Exhaust manifold as the stock 2JZ-GE manifolds would not quite clear.
This pic sums it up pretty well![]()
I actually already have the flanges cut for a set of Custom JMR pipes but the 1JZ-GE manifold got me out of trouble and I just have not had them done yet.
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
That's pretty much what I have, although I only have a 3" high flow cat have the 2 1/4" exhaust resonator and a 3" cannonOriginally Posted by 1983supra
The limitation is because its a steering BOX, not rack and pinion.Originally Posted by 1983supra
MA61's are racks so they will have different limitations, but from what ive seen factory exhausts (at least for N/A) clear the steering column.
Originally Posted by skiddz
In an MA61 the off the shelf headers like Xerd and Tune Agent won't clear the steering column and alterations are not an option, hence the need to fabricate a custom set.
Steering box is a major PITA. Only way out is custom or 1JZGE exhaust manifold.
Or retrofit a steering rack ehOriginally Posted by gianttomato
You mean futuro-fitOriginally Posted by takai
Yep, you could do that too!![]()
