Page 6 of 6 FirstFirst ... 456
Results 76 to 88 of 88
Thread: Idle control valves... types?
  1. #76
    Default Re: Idle control valves... types?
    If your going to have to buy something new, try find the 3 wire bosch valve. Uses solenoid action to both open and close it, instead of relying on a spring.
    I have the 2 wire valve, haven't had the opportunity to test it out yet though, will let you know how it goes.
  2. #77
    Hayndai excell has a fairly substantial bosch (or bosch-derived) PWM-driven Aux-air valve. Inlets are larger than the Ford unit.
  3. #78
    Thats some useful info chuckie... i might look one of them up
    I was having difficulty with the Ford XF unit, as apparently they are controlled by modulating the frequency, and not the pulse width....
    On a large motor, the XF would have enough control... but on my little 18RG, it didnt quite have enough control over the smaller volumes of air.
  4. #79
    Penrith BC
    so would one describe that XF IACV as a 'plunger type' or a 'vacuum type' - repco lists both types of valve for the XF and they want to know which one to order in for me...
    ed
    ../delete/ban
    tech moderator
  5. #80
    fudged if i know.... picknpayless had heaps of them and they cost like $15ea
  6. #81
    Penrith BC
    anyone wanna go to PNPL in the next 24hrs??????? please?????
    ../delete/ban
    tech moderator
  7. #82
    i probably even have one sitting in my garage doing nothing.
  8. #83
    Penrith BC
    karl - call me please
    0409603238
    ../delete/ban
    tech moderator
  9. #84
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    while we are on the subject,
    i swapped my gen2 3sge in but retained the gen 1 management, the Gen 1 has a Mechanical wax idle control but the gen 2 has a 3 wire electric one Atm i just have the Valve blocked off which causes me the problem of stalling till the engine is up to operating temp, then all is fine
    is there a way that i could have a switch on the dash for cold /warm as a simple control for this problem and if possible use the factory 3 wire valve ? got no idea how its controlled though
    thanks for any help in advance
  10. #85
    ed: does repco say if their catalog has a picture? it's a fairly visually unique item.
    i think the XF unit as previously mention ed and pictured is a "plunger" type in that the valve is held back by a spring and the motor forces it open by varying amounts.
    By vacuum type, i'd guess that there is one version that uses manifold vacuum to either open/close a valve, or uses vacuum instead of a spring - neither of those methods sound very useful if you don't have a large plenum or vacuum reservoir.
    Karl: it might pay to get someone to check that it's not some kind of oddball motor inside the Hayundai unit. I have one here - but no easy way of setting up a PWM driver without disabling the red car.
  11. #86
    Ed,
    The Ford valve you are chasing is no longer available from Ford or any aftermarket supplier I am aware of.
    Part Number - XF9F715A, New they were just over $200
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  12. #87
    hi guys
    sorry to wake a cold thread, but i'm looking to replace my setup with a plain TB and IACV.
    i'm looking for the IACV inlet/outlet to be hose fittings and the body of it not to bulky. PWM preffered.
    thechuckster said some Hyundai's
    anyone else offer some suggestions?
    i've seen this on ebay from a BMW 318i (pic below)
    that's what i'm looking for, but any others?
    RA65 - Project Car
    RT142- The 'I'm not sure what to do with it' car. (donor car)
    YZF1000R Thunderace
  13. #88
    BHGBTDT Domestic Engineer kemicalx's Avatar
    I'm currently toying with one of the hyundai/bosch PWM valves, seems to be reasonably good. Though I don't know exactly what frequency I should be feeding it.. I've got one side earthed through a resistor, and the other earthed via the wpm output of my ecu.. It's working ok, but not perfectly.
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 07:11 PM
  2. Microtech VS EMS stinger
    By mullett in forum Tech and Conversions
    Last Post: 04-05-2006, 09:11 PM
  3. 1jz: unusual high idle on cold-start
    By bk_ in forum Tech and Conversions
    Last Post: 27-04-2006, 08:25 PM
  4. Replies: 9
    Last Post: 21-03-2006, 11:41 AM
