Results 16 to 30 of 55
Thread: 4 link suspension
    Default Re: 4 link suspension
    so going to a steel bush replacing the urethane ones will be similar to running a rose joint on there then?
    I still have to check that it is the bush that is stuffed and not either the bolt holding it or the bit that it attaches to on the chassis.
    QUICKEST 1JZ'S IN OZ
    Yes very similar exept no ajustment exepts by offsetting the cetre hole location and then you would ave to weld the bush to the outside of the arm so it didnt move the setting etc.
    With solid bush you wont have lateral movment so it will put mor stress on things than the rose joint! but will do a similar job for lower cost if you make them yourself etc, best way is still rose joints, which you have to pay for then you have to pay for threaded bars to take the rose joints. The beauty of the rose joints is you can change the setting very quickly aswell between runs
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Running steel bushes are not the same as rose joints!!
    Rose joints/heim joints/spherical bushes will allow some movement other than at 90 degrees to pivot bolt.
    Unless al the arrms are all exactly parallel, and the differential only moves in a perfectly level plane steel bushes will bind something horid and put a fiar bit of twisting pressure on things.
    Have yet to see a drag car with suspension that does not try and twist rear end on launch, steel bushes are going to be fairly hard on rear end and body.
    regards
    jon
    um i guess you didnt read my last post! hahahahahahaha
    Jun 2006
    Yes i saw that just after i posted mine, must have come up while i was typing.
    regards
    jon
    heheheehe thought so cause you wrote pretty much what i did!
    ok, Mick says that they are similar except no adjustments and will be hard on the diff.
    Jon says that they will bind badly.
    Do you think I should try them out and see how they go as I was planning to race this Saturday?
    I don't really care about adjustment at this stage, I just want to be sure that my diff is still going to be pointing the same direction as it was before I started!
    you can just use two! one in the broken ones place and one same bot on the other side, just use it there and the other nothelene ones can take the load out
    remmeber it isnt ideal its a cheap quick fix
    Jun 2006
    I wouldn't use them on my car, regardless of its use, the only way the diff can tilt relative to the vehicle is to twist something.
    regards
    jon
    its a top front link.
    Ok I am going to do it. As mick says there is still urethane bushes at the diff end. Plus the rubber ones on the lower arms.
    Now need to find someone to make some
    Will get some piccies.
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    Hey Chris,
    Just thought I'd give you an idea of what I've just completed on my rear end. We fabricated 'moly arms and used teflon-lined rod ends. Not sure if this is the sort of setup you are after, but it might give you a couple of ideas.
    http://www.toymods.net/forums/showth...?t=544&page=12
    Jeremy.
    I am not a doctor, or a mechanic...
    A.K.A Otomoto
    All new - Fart!
    Quote Originally Posted by Vios-GT_07
    it was 10,000 kms b4 it saw the red-line.. but even then i seldom push it that hard unless i have to prove a point i.e. competition
    what rose joints are those? there not Qa1 or aurora!
    New South Wales
    Quote Originally Posted by kingmick
    National Rod Ends. We bought 30 of them at around $47 each from memory.
    A.K.A Otomoto
    All new - Fart!
    cool, i have yet to use them, i mainly use aurora and qa1
  1. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  2. ke25 suspension upgrade
    By styler in forum Tech and Conversions
    Last Post: 24-08-2006, 05:12 PM
  3. Your suspension & you...
    Last Post: 23-05-2006, 08:41 AM
  4. SW20 Complete Suspension Kit - Part Numbers?
    Last Post: 25-04-2006, 09:22 PM
