A few inserts should be available for the KE25 strut, I have Bilsteins in mine. They have been great and are about 5 years old now.new damper insert - seems like there is much technology in these things - gas filled, twin tube, special rates of movement and lots more,
some of them being a feature only to the specific manufacturer.
pedders, monroe etc lower end koni, bilsten higher end..
Probably aim higher than Pedders and Monroe![]()
Whiteline make an uprated sway bar to fit the KE25. I am not aware of any other vehicle having a sway bar that would fit the KE20/25?Swaybars....only thickness varies to stiffen the ride and same product from manufacturers. i did see soemthing about some sort of twist rate too. maybe another cars swaybar may be used.
Adjustable strut tops will get you the camber you want. The best adjustable strut tops available for the KE25 appear to be the T3 ones (they make them for the TE27 (called the Mango Corolla)). T3 = http://www.technotoytuning.com/produ...er_plates.htmlim leaning towards spacers for 2mm (I assume you mean degrees) neg camber if anything or adjustable strut tops if not expensive.
The K-Mac adjustable strut tops won't allow enough range to achieve 2 degree neg camber.
NOTE: if you are going to try and achieve 2 degree neg camber using the strut tops you may find that you springs will collide with the inside of the strut tower. You may need coil-overs to get the camber you desire (the smaller diameter spring will give you much more room inside the strut tower).
I don't think it is unless you plan on lots of caster. I can dial in enough caster (can't remember how many degrees??) for my tyres to rub on the front bottom part of the guard and there is plenty of thread left on my radius rods. T3 also make radius rods for the KE25.is it worth putting some more thread on the rods to wind it up a bit more or will big caster interfere with the suspension geometry or rub components?
My leaves were reset and an extra leaf was added which cost about $300 back in the day. My car doesn't tramp at all. My leaves currently are flat when the car is static.leaves checked out if ok maybe swap sides, add leaf, add leaf to front of pack, add clamp like = sign to front, invert whole pack and invert eyes under heat (thanks superjamie for the last 3 methods). or maybe a lowered stiffer spring pack if avaliable or custom made if affordable?
In my car I run Bilstein shocks front and rear, Eibach springs up front on height adjustable coil-overs. As mentioned earlier the rear leaves have been reset and an extra leaf added. All bushes have been replaced, tied rod ends replaced and ball joints replaced. It all handles quite well.
Good luck with it.
