Page 16 of 25 FirstFirst ... 61415161718 ... LastLast
Results 226 to 240 of 370
Thread: The Tips and Tricks thread
  1. #226
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Default Re: The Tips and Tricks thread
    Always, always, always use an impact socket to take diff/gearbox drain/filler plugs out with. Saves rounding the plug and alot of unesscary effort. Best $15 i've spent.
    And give the bolt a few good bashes with a hammer first. Much easier to get it undone.
  2. #227
    Never rounded a bolt with my Kincrome sockets... and Ive had to hang poles off the breaker bar. Buy good tools and you wont have these problems, unless the bolt has had a problem previously. And yes, Ive removed a reasonable few drain/fill plugs from boxes and diffs with the set I currently have.
  3. #228
    T'ville, QLD
    i only use 6 sided sockets say no to evil with 12 sides
    wd40 on birdshit and/or bug bits on your paint
    also for those who have a short attention span wd40 also attracts the fishies so next time your out in the boat spray your bait with it
    2T out 4A in....
  4. #229
    Rather illegal, but apparently works Isn't WD40 just turps in a can?
    244rwkw / 328hp @ 18psi
  5. #230
    Quote Originally Posted by Ribfeast
    How can spraying bait with WD40 be illegal?? Its not like your throwing a stick of TNT into the pond
  6. #231
    Junior Member Backyard Mechanic haison's Avatar
    Seconded.
    Have yet to round a single bolt with my Kincrome set. Including diff/gearbox plugs.
    1984 MA61 - http://www.toymods.net/forums/showthread.php?t=12340
    1972 RT81 - http://www.toymods.net/forums/showthread.php?t=24160
    RObErT_RaTh - I think it's fair to say we all love the bush
    Viper_Nipplex - If bush is this popular, just wait until the boxes are ready
  7. #232
    Polluting the waterways, like pouring motor oil or fuel in, but on a smaller scale. Heck if it works, I'd do it too, not like you are putting a whole lot on
  8. #233
    Just Soarin' Automotive Encyclopaedia derekjay's Avatar
    Might not want to eat the fish later though
  9. #234
    Gut them before it soaks in Not like it takes hours to pull in a fish (unlike a marlin... which you cant eat anyway) and you should bleed and gut them straight away anyways... good berley
    I would like them to show me the proof of the 'pollution' from a bit of WD40... the PPM concentration in the water surrounding it would be so minute it would be immesurable. Besides, you can just say you were preventing the hooks from corroding
  10. #235
    Yeah theres no oil/petrol in the ocean apart from every boat that releases it through the exhaust.
    New tip: When fabricating caliper brackets or brake setups make sure you have new pads and discs at standard thickness when fabricating upgrades up.
  11. #236
    T'ville, QLD
    THANK YOU!!!!! im about to start fucking with my ta22 rear brakes and i completely forgot about this!! ill email you a beer if you like
    oh and wd40 isnt toxic, but i wouldnt go using it as a seasoning.....
    2T out 4A in....
  12. #237
    WD40 is also great for getting stubbon black greasey/oily muck off your hands too!
  13. #238
    car connoisseur Grease Monkey essaysixtythree's Avatar
    Tasmania
    If you ever snap a gear linkage a length of fencing wire in some pvc pipe will let you change gears till you can get a new linkage. Might come in handy...
  14. #239
    Lightbulb Re: The Tips and Tricks thread
    Found another use for the automotive carpet Bunnings sell. It is quite a bit thicker than sub box carpet, and has a "short nap". I was about to reassemble some TA22 Celica door cards, and rear quater cards. The rear card inner belt moulding with the furry edges were totally stuffed. The hairy crap just fell off in my hands.
    The structure of the belt, and the chrome/stainless were still in good nick, so I trimmed off all the remnants of the fur with the trusty stanly knike, and used some contact adhesive, to bond some of the Bunning's carpet to the belt body. Waited 45 minutes, and trimmed the excess off.
    Looks good, fits, and will do an admirable job of acting as an an anti rattle device, the intended purpose of the belt.
    cheers Chuck.
    MS51Crown Coupe,
  15. #240
    For TA22 Celica owners, who are having trouble finding heater hoses I have a solution.
    This should work for stock 2T, and re engined TA22's. My trial of this was a 4A-GE.
    The AE92 heater pipe firewall grommet will fit the TA22 firewall with a bit of effort. No mods required. Pick them up at wreckers, free or a couple of dollars, probably still availbale from Toyota brand spanking new.
    The AE92 uses pipes not hoses, a little different to the TA22's. So find a couple of pieces of brass heater pipe, straight or 90deg bend dependent on your engine. Pick up 4 hose clamps, and some generic heater hoses of suitable length. (there is a very very long commodore hose readily available) Cut the pipe to suit and connect these to the heater tap/core with some of your rubber hose, and connect your engine hoses at the other side of the firewall after fitting the AE92 grommet. Job done.
    Hope this helps, cheers Chuck.
    MS51Crown Coupe,
