To remove a stubborn spigot bearing pack behind it with grease then using a punch the same size as the hole, hit it with a hammer compressing the grease and pushing the bearing out.
One way of removing rounded off bolts is the use a hacksaw accross the head of the bolt tuning it into a screw, then just get a screwdriver.
Screwdrivers with a square shaft are better than those with a round shaft as you can lock a shifter onto the shaft for more leverage, much better than vice grips on a round shaft.
Invest in one of those magnets on a stick, makes it easier to pick up those nuts and bolts you dropped into tight spots. These are also awesome for putting the locking pins on camsshaft gears for a 2tg.
If you havn't got an oil filter wrench then a belt does the trick, you know those things that hold your pants up.
Note: I'm a little worried with the level of interest in hand cleaning just go and buy some hand cleaner it's worth the money, if it wasn't then wouldn't every profesional workshop be using these remedies.
first socket death
