Page 18 of 25 FirstFirst ... 81617181920 ... LastLast
Results 256 to 270 of 370
Thread: The Tips and Tricks thread
  1. #256
    Default Re: The Tips and Tricks thread
    helpful posts dont make really good sig quotes
  2. #257
    stunt dog Backyard Mechanic Esteban's Avatar
    wa
    Owen LOVES balls!
    There's a quote for you, tomvale
  3. #258
    Convictania
    thankyou kind sir, but I am attached to my Full Metal Jacket adaptation.
  4. #259
    Please don't spank my Backyard Mechanic The Green Terror's Avatar
    Quote Originally Posted by TooF
    yes but thats a pintara
    my old corona would run on my home brew if i asked it nicely but the mr2 spits the dummy on anything less then 8000 or ultimate.
    My mighty 2T powered celica is the same, but does run somewhat nicer with ron95 or better.
    "Don't you know there is no Devil, there's just God when he's drunk" Tom Waits - Heart Attack & Vine
  5. #260
    Quote Originally Posted by Esteban
    Owen LOVES balls!
    Yeah, I am an avid cricketer, and I do prefer bowling. But unlike you, I don't like batting for the other team
    Ontopic EDIT: My tip for the day is to never fall asleep in the same room as Esteban without at least one layer of iron underwear on (unless you like that sort of thing)
  6. #261
    Don't know if these have been done
    If you have an outer bearing race stuck in a hub (eg wheel hub), smash all the balls/rollers out and run a bead of weld around the inside of the race. This causes it to shrink allowing much easier removal.
    When assemling new wheel bearings that are the more modern opposed angular contact bearing cartrage, heat the hub up in the oven to about 110/120 degrees C and place the bearing in the freezer. Have some decent gloves to handle the hub, put some thin lube (even WD40 type spray) on the bearing and quickly push the bearing into the hub, making sure you start it square. If it doesn't start after a couple of attempts, put the bits back in their respective heater/coolers. You have to be ready as everything starts to cool and warm straight away, reducing your crearance. Have a drift that is just smaller in diameter than the outer race and a hammer ready incase the bearing gets stuck once started. Only ever tap the outer race for assembly.
  7. #262
    Tasmania
    yep thats a good one, i use this method frequently (fitter and machineist by trade), but i find that not using the fridge/freezer is better because when they come into instant contact the heat transfers too quick, but if the smaller (bearing in this case) is warmer then its more successful.
    welding the race works to shrink works too, dont need to do the whole race, just more then half on opposing sides, and try not to get spatter on the inner bearing seat
    1973 TA22
  8. #263
    Quote Originally Posted by Cuts
    Snap
  9. #264
    For the major Oil spilage, you can go to bunning and ask them for the sawdust from their cutting machines. Spread it over the oil spill and it soaks it up and sweep up.
    Simon
    Beige.... The new Black!!!
  10. #265
    Kitty litter is also good, you need to get the fibrous stuff, not the pebbles (though crushing up the pebbles works at a pinch)... it will soak EVERYTHING out of your concrete, not just the oil you spilt.
  11. #266
    AB
    Quote Originally Posted by allencr
    While we certainly believe that you've seen a dead/drained battery, it WAS NOT because of concrete or lack of wood according to the myth, it was just coincidence - nothing more.
    its from the cold thats usually found in concrete. if you have a heating system in your floor (like me) then you can put and leave whatever you feel like there. if its cold not so much.. almost all batteries start failing at that -1 celsius the only batteries (that i know of) to contradict this are the lithium batteries...... i dont think they make them for automotive use, but i haven't looked.
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
  12. #267
    Junior Member Grease Monkey gazza53's Avatar
    Kitty litter is the go for any spillz except paint,
    I am the manager of the plant that makes the "Breeders Choice" brand.
    If you spray old oil that has soaked into yr concrete then put kitty litter on top, leave it for a couple of weeks, draws most of the oil out of the cement.
    Also a very good garden mulch, keeps the soil drying out round yr plant roots.
  13. #268
    Dont know if this has been said yet but anyway.
    Those spray bottles of waterless wash i sonly good for cleaning ya windscreen, Is a pain to put on at the start but once its rubbed in/dry it works wonders when it rains. No need for wipers.
  14. #269
    Instead of piss farting around with rusted nuts and bolts, try a product called YIELD. It costs plenty, but is heaps better than WD40 and the like. I got mine from Blackwoods as it's much more of an industrial type product. Be prepared for a decent bill
  15. #270
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Quote Originally Posted by Lambolica
    Simon
    also on the saw dust note it is awesome for killing everything in your garden,
    if you want to level some ground and pave or just scatter blue metal (basalt) it will kill everything underneath because of its acidity... no weeds or grass trying to grow through!
    not too car related but handy
    Peter.
