Page 3 of 9 FirstFirst 12345 ... LastLast
Results 31 to 45 of 122
Thread: Glazed Synchros from Redline Shockproof (R154)
    Default Re: Glazed Synchros from Redline Shockproof (R154)
    Don't Redline recommend MTL if you use their advice guide?
    Is this so, Hoff? Did you use the wrong fluid for your gearbox?
    seeyuzz
    river
    In the Hoffs defence if any I would say his would be classed as a race application with the numbers he's turning out.... but maybe Redline wouldn't see it as so.
    Black Betty >HERE!<
    (\__/)
    Trouble is they wont because it has syncros! Lol even was racing with a dog box, There is no warranty on race parts,Everything made has to have some sort of warranty but with racing they can get out of it very very easy.
    Was there much metal when you dumped the Oil Hoff?
    Lucky for Hoff and Hoff-clones around the world, Red Line Oil has come out with a new product. Check out the promo......
    nyuk nyuk nyuk
    seeyuzz
    river
    Quote Originally Posted by rogue-vl
    Has any one noticed that redline produce a Manual Transmission oil, MTL designed to be used in transmissoins with synchros, Shockproof is designed for racing box or diffs. read the info about their products it clearly states there.
    I think that using the correct fluid for the gearbox would have not resulted in the the glazing of the synchros.
    I will be using Redline MTL in my R154.
    Yeah last time i listen to recomendations from people that own R154's.
    And no, there was no metal at all, oil was perfect and blue, might have something to do with the rate i keep breaking things.
    Box would be lucky to have seen 800km with that oil.
    River - ha, you're awesome. You will feel my wrath one day old man.
    it says in there that MTL is better for syncomesh. If this was the case MTL should yeild better shifting quality than lightweight shockproof. but it doesnt. explain that?
    It is a given fact that lightweight shockproof improves shifting quality over MTL.
    JZA70|R / 12.45 @ 111 mph.
  8. #38
    by "better for synchromesh", they probably mean "will not glaze synchros" , hence it is better
  9. #39
    i dont understand how an oil could glaze syncro's when its actually helping them achieve better 'grip'.?
    when something glazes its because its slipping and heating up correct? well wouldnt the oil with the poorest shifting quality more than likely cause this effect, not the oil actually making the gearbox 'work'? :|
    *que gearbox expert*
  10. #40
    Offset is king Grease Monkey monkeymajik's Avatar
    I have had shockproof in this t50 for about 3000km's now. Shift quality was a noticable step up from Castrol Syntrax. Car doesnt do many road km's though.
    monkeymajik
    "Recommended for those who prefer
    hot driving action and big angle drift."
    JDM Style Tuning - Super Late Braking Technique!
  11. #41
    oil prevents friction... synchros need friction.... need a balance
    Syncros need slip .. thats how.
    I assume a thin oil is smoother but less of a coating and then thinner coats heat and glaze??
    Black Betty >HERE!<
    (\__/)
  12. #42
    i should also mention.
    It now has VMX80 and it has never shifted better! No longer notchy and goes into gear smoothly everytime! Almost like feels like a W58!
  13. #43
    glen - do you mind disclosing how much your twin plate set you back?
    I'll be needing a new clutch in the not too distant future, and I'm tossing up between a twin plate and getting a clutch place to build me a hybrid full-face (or button?) to deal with it... I'm guessing our setups will be making similar power/torque
  14. #44
    Congrats baz, I'll be in Sydney for the Fest (Toyota Fest, not fag fest, sorry), see if you can keep it alive until then! And good to see you took my advice on the vmx80, my consultation bill is in the mail.
    Redline, FTL!
  15. #45
    vic
    Good to here it worked Glen , as i said i only use vmx m in them and they work fine .vmx 80 is basiclly the same light gear oil
    Dave
  1. r154 shifting experiences
    Last Post: 24-11-2009, 09:47 PM
