cost me $8 per plug and $13 for the 90915YZZD2 filter
wow, thats cheap
ill have to check with my toyota the price, if not contact castle hill, good work on the heads up![]()
hello
how much is the oil filter for the 1g i got a ryco brand should i get toyota?
Anyone know where i will get an exhaust flange seal for the standard turbos to the dump pipe on a gen 3? Asked at autopro and they said they may be able to match something? Am i better off giving toyota a call? Part number? or is it a universal type part?
RA28, 1GGTE, Gen 3.
http://www.toymods.net/forums/showthread.php?t=3778
I got one from an exhaust shop
Take the dump pipe in, and get it matched, it's a strange shape, BUT they only run a "ring" gasket. The one I got was like 0.2mm to small to go on, but some gentle tapping allowed me to get it on, and then bolting it on pushed it the rest of the way on fully sealed.
just ring toyota if its your only transport.
if not that sheet of shit, that you cut your own gasket out off could be handy...
Ill check some exh places. Its not really suitable for gasket sheet as it is a ring style design, the thick crush type gasket. Thanks guys.
RA28, 1GGTE, Gen 3.
Take the dump to a shop, they'll give you one, that's all I did for the dump...
It was other gaskets I made myself.
Originally Posted by Kyosho
dump gasket is far different..........
hello
hey guys, is there a torque setting for clutch plate -> flywheel bolts?
cant see one listed in my info, just tight, about as tight as they were when you took them off....
tight and lock tight usually works well if in doubt...
tighten them up until start to go loose, thne back them off a turn or 2
'77 RA28LT #2 ← 2.2L 18RG...
Crank x flywheel:
750kg-cm or 54ft-lb or 74N-m
Flywheel x clutch cover:
195 kg-cm or 14ft-lb or 19N-m
Edited for truth
hmm i didnt understand that....i'm just gonna do em up tight, shud be rite.Originally Posted by RAd28
thegreatestben, i think thats flywheel bolt torque.
So it is, I shouldnt post when i should be sleeping.
The flywheel x clutch plate is
195kg-cm or 14ft-lb or 19N-m
