i've found that the body length of the strut is actually about 10mm shorter from memory.Originally Posted by SeptemberSquall
problemo was the the steering knuckle. the bolt spacing is out by about 2mm...
so my solution was to leave the front locating dough in the knuckle and ovalise the rear most bolt hole to allow it to fit.
now i haven't driven the car nor will i for a long time but i believe that it will work as i have had a mate do the same thing and it was fine for him. but i will look into using the mx62 steering knuckle or somethiing that will fit... maybe if the taper is wrong a bit of machininhg could make it fit?
