Originally Posted by
celbelle
Hey all,
Having some issues running a fuel pump and being a total rookie I have no idea what to do next.
The car is a '73 Celica Ta22 with a 2tgeu. Previous owner installed a swirl pot in the boot to accommodate the efi system.
System includes two pumps. One low pressure between fuel tank and swirl, and one high pressure between swirl and rail.
Problem is the high pressure pump that goes to the rail won't run, and the low pressure pump doesn't have enough guts to get the fuel to the rail.
Tested the pump - it's fine.
The confusing part is that both pumps are wired to the coil. Low pressure pump that works - wired to the positive side of the coil. High pressure pump that doesn't work - wired to the negative side of the coil. (how anything could run off the negative side of the coil is too much for my little brain - but that's how the car was purchased and ran for years)
Now, when I attach the high pressure pump to the positive side of the coil - it runs. But if I try to run both pumps off the positive side - nothing.
Does anyone have an idea what the deal is? and what would be the best way to get it running? (this was supposed to be the easy first step of the rebuild ha ha ha)
