tell me.
Is it really a must, to use gasket glue on the timing case cover. When i've already put it on using gasket paper?
i was going to put the glue also, but couldn't find it, until i actually fitted the cover...then presto there it is. ;(
On gasket glue, do u guys recommend it for cork sump gaskets. I wasn't happy with the last cork gasket and glue combo, but will it be better without?
my previous RA28, R.I.P is here.
http://forums.toymods.org.au/index.p...t=0#msg_651396
Current build here.http://www.toymods.net/forums/showthread.php?t=33512
I put mine together without gasket glue once and it leaked, it's such a pain to pull the cover off again. Better off been safe than sorry.
Alex
I was hoping you wouldn't say that.
At least its only the timing case cover to re-do.
On mine I use permatex aviation gasket cement on all paper gaskets. Head gasket got hylomar all over, and a tiny dab of ultra blue on the corners where the block and timing cover meet. Sump gasket got ultra blue dabs where the block and timing cover/ rear main seal casing meet, plus a smear along both of those. It then got a full bead of ultra blue between the sump and the gasket, as the sump mating surface was pretty ratty.
I didn't use any on the half moons as mine were new, but have used it in the past when recycling old hard ones.
The cork gasket on the block breather got the aviation stuff too. That shit is the bomb!
The cork risks leaking at joints if they aren't machined well. My sump was pretty banged up on the flange, so if yours is good you should be able to get away without the goo
I use a light smear of toyota black seal packing on pretty much all gaskets, gives me extra peace of mind.
Well if we are comparing gasket glue the best is threebond.
http://www.threebond.com.au/liquid-gaskets.html
Alex
I've got a blue gasket glue ATM. Not sure of the brand.
But the sump had to be hammered and flattened at each bolt hole, as it started to stretch and curve.
So the seal would've never been a solid flat seal.
One step forward, two step back with this engine...
thanks for the Info.
